587,229 active members*
6,282 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > CNC LATHE MORI SEIKI Diagnostic Parameter
    Jul 2006
    8
    Unhappy CNC LATHE MORI SEIKI Diagnostic Parameter
    Hi Guys, this is my first post in CNC Zone. I am having problem with this 1989 model of Mori seiki SL-15,
    Error : 911 Ram parity error ( HIGH).
    So i just Del the parameters and start entering the parameters again, but i coldn't get the diagnostic parameters entered. although i tried several times but useless i even check the edit and mdi modes.
    Master board
    A16B-1212-021
    MEM: A028-0098-B511
    I don't know if i missed something. please help me out.
    May 2007
    17
    Did you turn on the parameter write enable switch in MDI first?
    Jul 2006
    8
    Problem Solved
    I didn' switch the program edit key manually, but now i solved this problem thanx any way but a different problem have come:
    408: servo alarm (Serial not ready)
    what does it means ? and how can i solve this problem
  1. Replies: 11
    Last Post: 07-16-2022, 12:13 AM
  2. Replies: 1
    Last Post: 01-25-2010, 08:13 PM
  3. Mori Seiki SL-403 Lathe
    By alc1960 in forum Mori Seiki lathes
    Last Post: 09-23-2008, 03:35 PM
  4. nam sun lathe/mori seiki knock off
    By jheyliger in forum Uncategorised MetalWorking Machines
    Last Post: 04-27-2008, 07:42 PM
  5. PMC PARAMETER MORI DL20MC LATHE
    By modulus in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-12-2008, 11:29 AM
