603,799 active members*
2,452 visitors online*
Results 1 to 6 of 6
    Sep 2016
    3
    CNC lathe will not read G01/G00
    Running CNC as usual...after finishing a part and chucking on next piece, machine stopped reading canned cycle when it gets to G00 line. Machine was not crashed, no power outage or overload. From one part to the next just stopped working. I have checked fuses and belts and there is nothing damaged. There are no alarms. A technician came out but was not able to find a problem. Has anyone dealt with this before?
    Dec 2008
    3215
    Re: CNC lathe will not read G01/G00
    Can you put up the NC code ?
    What machine & control ?
    Is the Rapid or Feed override switch turned to zero ?
    Sep 2016
    3
    FEMCO HL-55 with FANUC oi-TC controls.
    Rapid and Feed override not on zero.
    Program is loaded properly and no changes made. Ran 4 parts complete before the problems began.
    Thanks.
    Check the System Diagnostic and see if any bits are turned at at the time that this happens. Press the System Function button then press the Diagnostic soft key to view
    Sep 2016
    3
    In the diagnostic screen the only lines that change are motion and interlock/start-lock...both go from 0 to 1, everything else stays at 0. thanks.
    You need to look at the ladder when machine is in this state. Check coil G8.0 and G130.0, G130.1 G130.2 If any of these are off you will have this condition. G8.0 stops all axes from moving while G130's are per axis, X, Y, Z. There is a parameter you can change to bypass these but you risk damage to your machine as the interlocks are preventing an axis from moving if the machine is in the wrong state
  1. Replies: 3
    Last Post: 06-13-2018, 12:48 PM
  2. DRO, Digital Read Out KIT for mini lathe BV20
    By branto73 in forum Mini Lathe
    Last Post: 01-10-2015, 01:54 AM
  3. Help Setting the Read-Out for lathe?
    By Fidelity_Mold in forum MetalWork Discussion
    Last Post: 10-25-2010, 05:09 PM
  4. digital read out for classic South Bend Lathe
    By meats in forum Benchtop Machines
    Last Post: 07-28-2009, 10:36 PM
