603,924 active members*
2,377 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > CNC Machine giving an "Arc destination not on arc" error
Results 1 to 4 of 4
    Apr 2021
    5
    Recently while trying to cut out a filet for a raised panel of a door using a parallel tool pathing strategy, my CNC machine gave an abrupt error. See the picture of the error attached.
    What is confusing is that it did the fillet quite fine for two of the edges, started the third one, and then stopped and gave the error. See attached images.
    Is it possibly an error with the post for my machine that it is not processing a set of ijk values properly? or, maybe something needs to be tweaked in Fusion? or, if someone has a post that works for Fusion to my machine. See machine name below.
    The CNC machine's name is Blue Elephant ELECNC 1530-ATC.
    I also attached the post that I am using.
    If something can be done to the post or in Fusion I would appreciate some sort of discussion where I would send whatever files or screenshots necessary to solve this problem. Thank you.
    Attached Files Attached Files
    Apr 2021
    5
    Re: CNC Machine giving an "Arc destination not on arc" error
    UPDATE (SOLVED)
    The issue was solved by enabling 3D and radius arcs in the post-processor menu. That seemed to have caused the issue.
    Nov 2011
    491
    Hello, this is Blue Elephant CNC.
    Please contact us if you need any help.
    Contact Information:
    https://www.elephant-cnc.com/
    Email: [email protected]
    Whatsapp/mobile: +86-15064026772
    E-mail: [email protected] Web: www.elephant-cnc.com
    --------------Jinan Blue Elephant CNC Machinery Co., Ltd-------------
    May 2024
    32
    Wow, very quick responce, it's nice to see how companies monitor users' issues with their machines in order to help their customers
  1. need help with "radius of arc not valid" error
    By remo99 in forum CNC Machining Centers
    Last Post: 08-04-2011, 05:36 PM
  2. "ERROR 416, Arc Endpoint does not lie on Arc".
    By borne2fly in forum Milltronics
    Last Post: 04-11-2011, 07:01 AM
  3. "jword given for arc in xz plane line number xxx" ???
    By HankMcSpank in forum G-Code Programing
    Last Post: 05-11-2009, 01:28 PM
  4. "Radius to end of arc differs" problems !
    By Geetar-ist in forum G-Code Programing
    Last Post: 12-16-2007, 07:22 PM
  5. Replies: 6
    Last Post: 07-07-2007, 01:43 AM
