603,946 active members*
2,465 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Polls > CNC Mill Machinist V. CNC Lathe Machinist
View Poll Results: Who is the more skilled cnc machinist?
Voters
21. You may not vote on this poll
  • CNC Mill Machinist
    6 28.57%
  • CNC Lathe Machinist
    2 9.52%
  • I am both so I rule!
    13 61.90%
Results 1 to 9 of 9
    Jan 2007
    243
    Back in the day, when I was working at a large CNC job shop, we had 2 machining departments. The CNC Milling Department and the CNC Turning Department. Naturally boys being boys we had an ongoing rivalry and much debate between the 2 departments as to who was more skilled. The CNC Mill Machinists or the CNC Lathe Machinists? ( I did both) What's your opinion?
    www.WebMachinist.Net
    The Ultimate Online Source for Machinist Related Stuff!
    Jun 2004
    511
    It all depends on the complexity of the work.
    Jul 2007
    378
    I have no opinion. They both have there challenges. I admire Lathe people for being able to produce a part with a limited amount of Tools and Tool clearance issiues. But milling programs can get rather complex at times. All I know is if you put me on a CNC lathe, I'd be crashing it left and right.
    Aug 2012
    71
    I suck at both, but I suck the least on the mill. So lathe guys rule.
    Feb 2007
    664
    define "Machinist"
    or do you mean machine operator , unless you can run it all your not a Machinist
    Jul 2005
    12177
    If you are indeed a Machinist then you run both, along with shapers, planers, grinders, etc. If you can only run one type of machine you are not a Machinist.
    Jan 2007
    243
    Actually, I would consider anyone that is a master of any type of major shop equipment to be a machinist. Just specializing in a certain type of machining.
    Nov 2012
    Quote Originally Posted by holbieone View Post
    define "Machinist"
    going off of this basis... would you say a "mechanic" isn't a mechanic unless he knows how to fix every type of vehicle?? car, truck, high end luxury, import, muscle, hot rod, hybrid, full electric?? and every component?? engine rebuild, tranny's, suspension, electronics???
    I myself have been in industry for 10 years, and am only now starting my apprenticeship, i have never worked on lathes in my life (other than in school) so i am not great in that aspect, but i know i can hold my own on a mill (CNC and Traditional).
    I consider myself a Machinist... and i am proud of it...http://www.cnczone.com/forums/images/smilies/banana.gif
    Feb 2007
    664
    Quote Originally Posted by TribalNewt View Post
    they would be called technicians
    "apprenticeship" , after your done with your apprenticeship you will be a Machinist
  1. CNC Lathe/Mill Machinist
    By cewolf3 in forum Employment Opportunity
    Last Post: 03-19-2013, 03:32 AM
  2. CNC Lathe Machinist
    By mattys281 in forum Employment Opportunity
    Last Post: 08-14-2012, 09:51 PM
  3. CNC Swiss Lathe Machinist!!
    By danielvalvarez1 in forum Employment Opportunity
    Last Post: 07-27-2012, 04:28 PM
  4. CNC LATHE SETUP MACHINIST
    Last Post: 07-05-2012, 07:20 PM
  5. Looking for CNC machinist/manual machinist in detroit metro area
    By Runner4404spd in forum Employment Opportunity
    Last Post: 11-12-2007, 07:11 PM
