603,936 active members*
3,331 visitors online*
Page 4 of 5 2345
Results 61 to 80 of 93
  1. #61
    Apr 2009
    109
    New version 2.10.1008.2201 is available
    I would also like to invite you to Planet CNC USB Controller Google group.
    New version 2.10.1008.2201 is available for download
    - Feed override in now editable - you can type in new value
    - Improved jog performance
    - Ctrl+Arrows and Ctrl+Shift+Arrows jogging with keyboard
    - Support for I2C protocol for controlling external devices. Source and schematics for my prototype "coordinate display" can be downloaded here: http://www.planet-cnc.com/diy/I2Cexa...ateDisplay.zip
    - Import DXF has new features needed for plasma and laset cutters (Pause - M02 is added).
    Best regards
    Andrej
    CNC USB controller - http://www.planet-cnc.com
  2. #62
    Jan 2006
    481
    Very Nice work Kroko
    Cheers
  3. #63
    Aug 2003
    329
    Nice work.
    I have a couple of short questions.
    1. Your controller does not need Mach 3, but can Mach3 be used with your controller anyway.
    2. Will your controller work with Geckodrives?
    Bill
  4. #64
    Apr 2009
    109
    Quote Originally Posted by bgriggs View Post
    No. At this moment controller does not work well with Mach3. You can download, install and test evaluation version of my software.
    Yes, it works with Geckodrives.
    Regards
    Andrej
  5. #65
    Jan 2005
    6
    Hi Kroko,
    I have been using Mach3 and am tired of trying to keep old DOS windows system running. Newer windows less than happy with it.
    I considered trying to devise my own PIC based USB buffered solution a few years back, but now I am happy to see youve already undertaken both the hard and software task.
    I am interested in both your board and in the Probotix board which seems to have a more comprehensive connector breakout than yours but otherwise, pretty much the same specs.
    They claim their board should be used with your software and show a US link for purchase of both.
    Are you supplying your windows program to them and is their board hard and firmware compatible with yours.
    I am in the US and would prefer US support, but you are clearly the originator and probably sole developer of this system and I would like to know your recommendation.
    Ive tested your eval version of your software and am very impressed. .NET and Direct 3D are daunting to say the least. I did some rudimentary game engine work and know it isn't easy.
    Great Job!
    Thank You, Gary McCray
  6. #66
    Apr 2009
    109
    Hi
    Probotix makes boards with my permission. Board has screw terminals. Pinout on headers is also different and compatible with other Probotix boards. You should choose any board you want. They both use same software and firmware.
    Best regards
    Andrej
  7. #67
    Apr 2009
    109
    I've made new 9 axis, 100kHz CNC USB Controller Mk2.
    Right now I'm programming support for MPG pendant which could be used to run machine manualy without PC.
    I also plan to make support for SD card which will allow to run programs (g-code) without PC.
  8. #68
    Jan 2005
    1880
    Nice man. everyone needs to go usb are a newer interface.....parallel ports are becoming hard to find!
    thanks
    Michael T.
    "If you don't stand for something, chances are, you'll fall for anything!"
  9. #69
    May 2011
    Quote Originally Posted by Hamish911 View Post
    Thank you for testing these configurations Kroko!
    I adjusted couple of things in software and now it runs on Linux. I used Ubuntu 8.10, VMware player 3.0 with WindowsXP installed. There is no 3d graphics but controller runs without problems.
    ________________
    Provigil
    Generic Provigil
    generic Provigil online
  10. #70
    Nov 2010
    please help i have a okuma mc-4va and i need the a-1 a-2 & b 8" floppy disk for my machine the sn# is 6208.0797 my phone is 501-728-3800 thanks tim baker
  11. #71
    Apr 2009
    109
    Quote Originally Posted by BakersMachine View Post
    I'm not sure I'm right person for you.
  12. #72
    Jan 2005
    1880
    Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!Share on Facebook
    ya, wrong thread dude!
    thanks
    Michael T.
  13. #73
    Apr 2009
    109
    I've made 3 videos demonstrating some of new features of Planet CNC USB Controller Mk2
    Demonstration of using MPG pendant with controller without PC.
    [nomedia="http://www.youtube.com/watch?v=iKxlxxc38v8"]YouTube - ‪CNC USB Controller Mk2 - MPG pendant‬‏[/nomedia]
    Demonstration of using transformation matrix. Workpiece is not positioned correctly. Tool sensor is used to measure actual workpiece position. This data is used to calculate transformation which maps g-code to workpiece correctly.
    [nomedia="http://www.youtube.com/watch?v=s9nTdEEFgyA"]YouTube - ‪CNC USB Controller Mk2 - Transformation matrix‬‏[/nomedia]
    Demonstration of using camera as tool sensor. Three known points are captured and used to calculate transformation. NC Drill (Excellon) file is used to drill holes into PBC. Because of transformation holes are exactly where they should be.
    [nomedia="http://www.youtube.com/watch?v=JJnenOsbCzU"]YouTube - ‪CNC USB Controller Mk2 - Drilling PCB using transformation matrix and camera sensor‬‏[/nomedia]
    Best regards
    Andrej
  14. #74
    Sep 2009
    Hello,
    Nice and impressive work.
    As your board works with Step/Dir to control drivers, is there any chance to control Servo motor Step/Dir drivers?
    Thanks,
    MLB
  15. #75
    Apr 2009
    109
    Thank you
    Controllers work with servo motor step/dir drivers. I will use servos on my new machine.
    Andrej
  16. #76
    Jan 2006
    156
    HI Kroko,
    I have very little experience with cnc so I have a question , will your controller and software run g-codes for a lathe . I am especialy interested in threading.
  17. #77
    Apr 2009
    109
    Controller will run G-code for lathes but current version is not optimized for lathe -
    RPM sensor is not supported and G95 (units per revolution) will not work. This is important for threading.
  18. #78
    Aug 2003
    329
    How many amps will your controller handle?
  19. #79
    Apr 2009
    109
    This is motion controller, not motor driver.
  20. #80
    Sep 2010
    717
    Quote Originally Posted by Kroko View Post
    There would be some outputs? How many mA can they drive? Or are they relays?
    Current build: http://www.cnczone.com/forums/diy-cnc-router-table-machines/264838-new-machine-desing-quot-cnm13-quot.html
Page 4 of 5 2345
  1. Yaskawa Motion Controller
    By curtisturner in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-08-2008, 07:27 PM
  2. the Motion group Controller
    By 47MLB in forum Machines running Mach Software
    Last Post: 07-23-2007, 10:16 PM
  3. 3-4 axis motion controller
    By grebator in forum Stepper Motors / Drives
    Last Post: 04-19-2007, 09:15 PM
  4. PARKER 6K2 or 6K4 Motion controller
    By TUCSONCNC in forum Post Processors for MC
    Last Post: 02-02-2007, 07:07 AM
  5. Can I use this motion controller to make cnc router?
    By Clasic31 in forum CNC Machine Related Electronics
    Last Post: 12-11-2003, 04:17 PM
