587,313 active members*
3,390 visitors online*
Page 5 of 5 345
Results 81 to 93 of 93
  1. #81
    Apr 2009
    109
    Outputs can handle 20mA.
    CNC USB controller - http://www.planet-cnc.com
  2. #82
    Sep 2010
    717
    Quote Originally Posted by Kroko View Post
    Cool thanks I'm actually considering buying your board (the MK2), would be great for my machine.
    Current build: http://www.cnczone.com/forums/diy-cnc-router-table-machines/264838-new-machine-desing-quot-cnm13-quot.html
  3. #83
    Mar 2009
    36
    I would like if somebody would design usb controller with four axis tb6560 on the same pcb
  4. #84
    Apr 2009
    109
    New, 4 axis version of Mk2 is available.
    • 100 kHz maximum step frequency
    • 3 digital outputs
    • 12 us minimum pulse width
    • manual jog inputs for all axes
    • limit inputs
    • 4 inputs
    • DB25 connector (simulates PC LPT parallel port for easy connection to existing systems)
    • screw terminal connectors for all inputs & outputs
    Attached Thumbnails Attached Thumbnails controllerMk24-b_800.jpg   controllerMk24_800.jpg
  5. #85
    Aug 2007
    7
    Hi, I'm rather new to cnc but tempted to build a hot wire cutter and/or router.
    Your controller seems to be quite good but at this time there's one thing I wonder about. "100 kHz maximum step frequency", is that per axis or in total for all?
  6. #86
    Apr 2009
    109
    With Mk2 9 axis controller all 9axis can step at 100kHz at same time.
  7. #87
    Aug 2007
    7
    Thank you for your answer.
    Since you explicitly state that the Mk2 9 axis controller can step at 100kHz with all axes at once, can I interpret this as that the Mk2 4 axis controller is not able to do this?
    Or can both Mk2 controllers step at 100kHz with all axes at once? ( Nine respectively four of course. )
    My apologies if I misunderstood your answer or am difficult to understand myself. English isn't my native language but I try to leave as little room as possible for misunderstandings.
  8. #88
    Apr 2009
    109
    Mk2/4 can do the same but it only has outputs for 4 axes. Difference between Mk2 and Mk2/4 is only in board layout. Internaly they are the same.
  9. #89
    Feb 2012
    ________________
    download 5000 backlinks
  10. #90
    Apr 2009
    109
    Each axis can step at 100kHz.
    If all 9 axis move at maximum speed then this is 9 * 100kHz.
  11. #91
    Dec 2012
    Pendant compatibility
    Hi Andrej, I just purchased te following from Probotix, and because I need pendant capability I think I must have gotten the wrong board:
    X3 CNC Conversion Stepper Motor Driver Kit - X3 CNC Conversion Stepper Motor Driver Kit
    I purchased the above with the ready to run, and USB board and software options. My questions are:
    1. Am I out of luck with the pendant mpg without the 9 axis board, and if so:
    2. Does Probotix carry that board or do I need to order from you directly? it doesn't seem to be on their website?
    3. What is required to switch out the boards.... Given the above kit?
  12. #92
    Apr 2009
    109
    You need Mk2 board to use MPG pendant.
    Probotix does not have it.
    You'll need to modify 10wire IDC cables like this:
    CNC USB Controller - Probotix 10pin cable
    Please use our forum for support questions.
    Planet CNC forum
  13. #93
    Mar 2006
    20
    Quote Originally Posted by Hamish911 View Post
    Does the windows software of this controller work from within a virtual machine?
    Has anyone tested this?
    I run Windows 7 with VM Fusion5 on my Macbook Pro 15", Mavericks.. I have the MK2/4 board and everything works. No issues.
    The hardware is great, the software superb and you get Kroko as your support . What more could you want.
    I love it. The more I work with it and the deeper I dig, the better it gets.
    I also used the system with a Win8 tablet PC running it off the micro USB port. Works a treat.
    The only thing I could put my finger on was the screen. It can not be customised like in Mach3. So I thought. But I found out it can be arranged in a way to suit any needs. It is very intuitive.
    There is a lot of "brain" behind this system. great job, Kroko
Page 5 of 5 345
  1. Yaskawa Motion Controller
    By curtisturner in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-08-2008, 07:27 PM
  2. the Motion group Controller
    By 47MLB in forum Machines running Mach Software
    Last Post: 07-23-2007, 10:16 PM
  3. 3-4 axis motion controller
    By grebator in forum Stepper Motors / Drives
    Last Post: 04-19-2007, 09:15 PM
  4. PARKER 6K2 or 6K4 Motion controller
    By TUCSONCNC in forum Post Processors for MC
    Last Post: 02-02-2007, 07:07 AM
  5. Can I use this motion controller to make cnc router?
    By Clasic31 in forum CNC Machine Related Electronics
    Last Post: 12-11-2003, 04:17 PM
