603,953 active members*
2,740 visitors online*
    Apr 2003
    416
    Compensating after stopping a move
    If I escape to stop a move (while in a program or in manual), the next manual move I issue is not performed until a compensation move is done.
    If I escape because I am in a cut that I do not want to continue, this is a problem.
    Why is this compensation done and is there a way to stop it?
    Bill
    Apr 2003
    131
    Good morning Bill!
    The compensation move is to take up backlash on a machine with slop in the feedscrews.
    Although it's been a while since I've looked at the E-stop logic, I think that the backlash preload registers are reset to "indeterminate" after an emergency stop in case the table has gotten knocked around a bit (broken or jammed cutter, vise with a new "feature" in it, etc). Thus, the next move is backlash compensated.
    You can get rid of this by deleting the lines in your turbocnc.ini file that look like this:
    Backlash=_some number in sci notation_
    for the axes in question and restarting the program.
    Another option would be to modify the source code - I believe it's the PanicStop() procedure that handles the interruption of motion when ESC is pressed or the external e-stop pin goes active.
  1. No Z up on move
    By cncadmin in forum Mach Software (ArtSoft software)
    Last Post: 03-20-2005, 07:08 PM
  2. The X-Axles... to move or not to move!
    By Wild4aces in forum Mechanical Calculations/Engineering Design
    Last Post: 03-18-2005, 08:26 PM
  3. Speed how fast an axis can move?
    By jlagran he in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-05-2005, 05:05 AM
  4. how does mach 2 and similar programs know how far to move ?
    By Apples in forum Uncategorised CAM Discussion
    Last Post: 05-11-2004, 08:43 AM
  5. User coordinate system?
    By HuFlungDung in forum OneCNC
    Last Post: 04-19-2003, 03:26 AM
