587,762 active members*
3,349 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Connecting two identical drivers to drive one stepper motor?
    Aug 2008
    18
    Hi
    Is it possible/advisable to connect two identical drivers to drive one stepper motor?
    I am planning to drive a 3.0A unipolar motor with two 1.5A driver.
    May 2008
    110
    I dont know why you would want to do this when you can run your motor as bi-polar and only use 1/2 the amps and at a heck of a lot less money.
    budP
    Not a good idea to double-up drives. The hotter a transistor gets, the more current it tries to carry. One drive gets hotter making the other drive a little cooler. The hotter drive starts carrying most of the current until it burns up. This is called 'current hogging'.
    Doubled-up drives instantly destroy themselves if they are switching type drives (L297, Allegro, etc). The drives are not synchronized at their switching frequency so one drive will have a motor output switched to GND while the other drive has its output switched to +supply. The short circuit current flowing out of one drive into the other one will destroy both of them instantly.
    Mariss
    Mariss
  1. Stepper Motor with 2 Drivers ??!!?
    By Santa Fe Al in forum Stepper Motors / Drives
    Last Post: 07-26-2008, 02:40 PM
  2. Cobra Stepper motor drivers
    By Jason Marsha in forum Viper Servo drives
    Last Post: 09-11-2007, 12:26 AM
  3. drivers for stepper motor?
    By visky in forum Stepper Motors / Drives
    Last Post: 01-22-2007, 09:27 PM
  4. stepper motor drivers
    By nurseling in forum CNC Machine Related Electronics
    Last Post: 01-16-2007, 11:43 PM
  5. Stepper motor drivers ?
    By Clyde Crashkop in forum Stepper Motors / Drives
    Last Post: 11-27-2006, 12:39 AM
