587,171 active members*
2,758 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Connection with Humidity sensor (4-20ma) and PLC or temperature controller
    Dec 2006
    39
    Hi all,
    I would like to know if I am able to connect a (4-20ma output) humidity sensor to temperature controller (PID control)
    Will the PID control goes haywire?
    If I connect the humidity sensor to my PLC analog input, what should be the next step? Customise the PID control on ladder?
    Which method is more feasible?
    Thanks.
    Rgds,
    Rainman
    Dec 2006
    39
    The whole thing looks like this......
    Jan 2007
    333
    A PLC should work fine..... Horner makes a decent one that should work (Xle) which has analog inputs, relay outputs and Modbus.
  1. Hall sensor connection
    By rainman in forum CNC Machine Related Electronics
    Last Post: 01-09-2008, 02:13 PM
  2. Proper Connection of Shuttle Jog Controller.
    By Willyb in forum Tormach Personal CNC Mill
    Last Post: 09-30-2007, 12:27 AM
  3. It's not the heat, it's the humidity
    By qroger in forum Environmental / Alternate Energy
    Last Post: 07-12-2007, 02:30 PM
  4. connecting 4-20mA device to analog input
    By Karl_T in forum CamSoft Products
    Last Post: 09-02-2006, 06:52 PM
  5. Parallel Port machine controller to computer connection HELP PLEASE!
    By whipsnade in forum DNC Problems and Solutions
    Last Post: 08-01-2006, 10:45 PM
