603,344 active members*
3,594 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Convert eps to g code for Mach 3?
Results 1 to 6 of 6
    Mar 2012
    54
    Hi guys,
    Hopefully I'm in the right place. I finally got my Multicam router up and going and I would like to cut something now. I get my files from illustrator and flexi saved as an eps. What free/purchase program can I use to get them from an eps to Mach 3 to cut?
    Thanks so much,
    Cody
    Mar 2003
    35494
    Re: Convert eps to g code for Mach 3?
    Vectric's V Carve Pro can import .eps files.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jun 2008
    562
    I think Illustrator can export DXF. Mach3 can import that I believe, I could be wrong though.
    Mike
    Oct 2013
    110
    Alphacam has an EPS importer and raster to vector function.
    Mar 2012
    54
    Thanks guys for all the info. I've narrowed it down to vetrics cut 2d or artcam. Can you guys help me decide which is a better product of the two?
    Mar 2003
    35494
    ArtCAM Express probably has a lot more features than Cut2D.
    Gerry
  1. New CNC with Servos - Should I convert from NCstudio to Mach 3 ???
    By mkp007 in forum Machines running Mach Software
    Last Post: 05-29-2014, 10:14 AM
  2. convert to mach 3
    By luvpakn in forum Mach Plasma / Laser
    Last Post: 12-28-2013, 05:40 AM
  3. SX3 convert ..Tapping with mach 3 possible
    By Vatorman in forum Benchtop Machines
    Last Post: 02-08-2011, 05:47 PM
  4. Help Convert .dfx to g-code please?
    By jsnbrgg in forum G-Code Programing
    Last Post: 11-29-2007, 06:02 PM
  5. Can someone convert it to G-code for me ?
    By rceebuilder in forum BobCad-Cam
    Last Post: 11-10-2006, 10:56 PM
