Does anyone know how to or have a program to convert jpeg or bmp to dfx...attached is a jpg file that I would like to engrave......Thanks :cheers:
Try a search like this- http://www.cnczone.com/forums/search.php?searchid=68546
not sure if this is what you want or not but her you go :P Adobe Streamline 4.0
Not a self-portrait I hope![]()
Al
Albert E.
this wwent thru signlab
Thanks alot guys....... :cheers:
This one was done with RasterFratz. Smoothness setting of 3.
Fred Smith - IMService
http://www.cadcamcadcam.com
Fred, can Rasterfratz create .dxf's that AutoCAD can open? ACAD 2002 couldn't open that one.
Gerry
UCCNC 2017 Screenset
Mach3 2010 Screenset
Gerry, do what you would do to open a DXF saved with Autocad rel 10,11,12,13,14, or 2000, but not in 2002. Maybe look for a file import or merge rather than a direct file open, which may be set to open DXF files created ONLY with rel 2002/2004/2005, etc.
Thank you Fred......That one is really nice...simulated it in Mach 2 and looks like what I was looking for....Thanks Again..... :cheers:
I will have to check out that software
Originally Posted by imserv
I get an error message saying table flags missing on line 38 - invalid or incomplete .dxf
AutoCAD doesn't care what version it's opening. There are no options. You open a .dxf with the open command, and select .dxf in the file type box. Any version should open this way. I guess AutoCAD is more picky than most because it's their format. Does Rasterfratz have .dxf version options when saving or exporting?
Gerry
I could not get it to work either, the second file that is. Has anyone tried wintopo ?
Steven
The one from Fred? imserv?
Gerry
Apparently it does care whose version. ;-)Originally Posted by ger21
There are no DXF versioning options in Rasterfratz. I try to keep it at the current VectorCam level, but it may be out of synch now.
Try the attached file from Vector 10 and see if it will open. If it does, I will update the DXF template in Rasterfratz.
http://www.cadcamcadcam.com/hobby
Yes, Fred, the Vector version opens fine. I tried the Rasterfratz one on my home computer and get the exact same error I got at work.
Gerry
just wondering if anyone had a problem opening the file
i posted
I tried it and could not open it.....
I opened it in bobcad and Cadstd with no problems
thanks Kenneth
www.lambertsrc.com
opened in solidworks fine too :P
I tried to import into Cad Std and it would not open it....Hmm...
The one that spezzaferro did is the only one I can't open...
