603,893 active members*
3,721 visitors online*
IndustryArena Forum > CAM Software > Mastercam > CONVERTING DWG FILES
Results 1 to 9 of 9
    Sep 2007
    92
    on a couple of our seats of MCX MR2, when I try to bring in a AUTOCAD file, the screen is blank, Do I have a setting wrong?? can anyone help with this please
    Jul 2008
    139
    Smile
    Try alt-F1 to bring the geometry into view. Usually my dwg/dxf files do the same thing.
    Sep 2007
    92
    I did the auto-fit function and checked that all the visible levels were on and still nothing, can you think of any thing else I might be overlooking? thanks,
    Jul 2008
    139
    Check screen statistics to see if there is any geometry at all.
    Aug 2007
    95
    Uncheck the blank paper space entities box and see if this helps.
    May 2007
    71
    thanks
    Apr 2003
    3578
    Could it be the file is a newer vrsion then your software supports?
    Can you post the DWG file and I will try in X2 and X3.
    Cadcam
    Software and hardware sales, contract Programming and Consultant , Cad-Cam Instructor .
    Aug 2008
    64
    It's entirely possible that the drawing was done in a Solid format then sent to paper space as an X-Ref which results in an empty drawing. I've seen this many times. If that is the case you are experiencing, there is actually no geometry whatsoever in the file you are opening, thus your blank screen. Ask the person who drafted the file and see what exactly was done to create it.
    Sep 2007
    92
    Thanks for everyone's help, but this problem turned out to be our die designer setting the permissions improperly for his saved DWG files, false alarm...my apologies.
  1. Converting Illustrator files to Gcode files
    By acoop101 in forum Uncategorised CAM Discussion
    Last Post: 03-10-2023, 11:13 PM
  2. Converting 3ds and max files to dxf, iges, stl....
    By jeffo2001 in forum OpenSource Software
    Last Post: 01-30-2014, 01:03 AM
  3. converting *.nc to *.ncp files
    By davidsutton in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-04-2007, 03:38 PM
  4. Problems converting DXF files
    By edo in forum NCPlot G-Code editor / backplotter
    Last Post: 03-04-2007, 04:12 AM
  5. converting MC files to DXF
    By Sprew in forum Mastercam
    Last Post: 11-04-2006, 06:18 PM
