603,945 active members*
3,972 visitors online*
Results 1 to 7 of 7
    Oct 2006
    106
    Problems converting DXF files
    I've been using the trial version and have had great success with simple files that I've drawn in TurboCAD, but I just can't seem to figure out what's going on with this file. This was created in Adobe Illustrator on a MAC and saved as a DXF file. I moved the file to my PC and was able to open and edit it in TurboCAD, but when I bring it in to NCPlot, I don't get the whole image and parts of it are mirrored. Here are screen dumps of TurboCAD and NCPlot. Any suggestions? Thanks.
    Mar 2003
    765
    If you can post the DXF file, I'll have a look at it.
    Thanks,
    Scott
    Oct 2006
    106
    Thanks for the offer, but the file is 2.4MB, too big to upload.
    Mar 2003
    765
    You can also send it to my email, file size shouldn't be a problem:
    [email protected]
    Thanks,
    Scott
    Mar 2003
    765
    Ed,
    I had a look at your file and noticed a couple of things. First, this file contains block instances, which NCPlot doesn't like. Try exploding (or whatever you call it in TurboCad) the drawing so that it doesn't contain any blocks. Secondly, this showed some mirrored objects when I loaded it into Rhino, so it might be the way TurboCad is saving it. If possible, save it as an R12 or R14 DXF file and try loading it into NCPlot again.
    Thanks,
    Scott
    Oct 2006
    106
    Thanks for looking at the file for me. I "Exploded" everything and found some 'Block Insertions' that I converted to Polylines. Still no luck. TurboCAD doesn't have options for different types of DXF files. I'll have to wait until tomorrow to look at this again.
    Mar 2003
    35494
    You might want to try using the .dxf converter at www.a9tech.com to convert it to an older version. And also, you can ususally zip a .dxf file down to a much smaller file size.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  1. COnverting 2D images to 3D cutting files
    By Salty72 in forum Coding
    Last Post: 04-15-2013, 04:52 AM
  2. converting MC files to DXF
    By Sprew in forum Mastercam
    Last Post: 11-04-2006, 06:18 PM
  3. Mach3 converting dxf files problem
    By randyf1965 in forum DIY CNC Router Table Machines
    Last Post: 04-19-2006, 05:28 AM
  4. converting blueprints to DFX or AUTOCAD files
    By toolmkr13 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-13-2005, 05:14 PM
  5. converting to dfx
    By qsacracer in forum G-Code Programing
    Last Post: 04-26-2005, 09:43 PM
