603,923 active members*
3,446 visitors online*
    Jun 2008
    44
    converting files to stl
    Hi
    I've recently downloaded some free artcam files from,
    FREE 3D SAMPLES | 3D MODEL.
    The artwork looks quite good do I want to cut a few pieces. Problem!
    Sample FS01 and FS02 open as STL file, that's fine, the rest open as RLF file witch I cannot open. Is there a way to translate them to STL? I'm making
    tool path with cut3d.
    Any help welcome, Gary.
    Aug 2008
    63
    Hi Gary
    As far as I know .rlf files can only be opened with ArtCam. Did a search and found this "You can convert RLF file to STL in ArtCam. Go to relief menu->create triangle mesh, create triangles->save triangles in STL."
    Gave it a go with ArtCam2008 and one of the free models from the link you provided and was able to open the resulting .stl in mastercamx3 no prob. So you will need ArtCam if you want to use the files, not sure what the Demo can do for you.
    Hope this helps
    Verm
    Jun 2008
    44
    Hi Verm
    Yes, found this solution as well, however I'm not buying for just a few files so I'm looking for a different solution.
    Gary.
  1. Converting Illustrator files to Gcode files
    By acoop101 in forum Uncategorised CAM Discussion
    Last Post: 03-10-2023, 11:13 PM
  2. Converting files
    By Crawler374 in forum CamBam
    Last Post: 01-09-2010, 07:40 PM
  3. CONVERTING DWG FILES
    By CNC_BOB in forum Mastercam
    Last Post: 11-13-2008, 12:52 AM
  4. converting *.nc to *.ncp files
    By davidsutton in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-04-2007, 03:38 PM
  5. converting MC files to DXF
    By Sprew in forum Mastercam
    Last Post: 11-04-2006, 06:18 PM
