603,884 active members*
4,945 visitors online*
Results 1 to 5 of 5
    Oct 2007
    16
    Copying Blocks
    Hi Guys,
    Next week I have to program various Lines/Arcs, and I want to duplicate the path, but using a different tool, which will also mill slightly deeper.
    I think it is possible to copy the first program, and then make adjustments to suit. Could someone please tell me how to copy Blocks?
    PS I am using a VM1 in conversational.
    Jul 2003
    71
    I'm not familiar with VM-1 but in Max2 there is a copy and change prompt on the Input screen.
    Jun 2008
    9
    Hit the "Review" key. On the right side you'll see your blocks, on the left you'll see the individual segments in the blocks. Hold down the "Alt" key on your keyboard and highlight all the blocks that you want to copy. (You may have to hit the softkey 'Multiple block options on the right pane first) Then paste them where you want them, even in another program if you like just like Windows. On the Input screen there is a Change Block Key that will allow you to also bulk change things like Speeds and Feeds and tools to a specified group of Blocks. Hope this helps.
    Apr 2008
    26
    From the inut screen choose the touch key on the right for "copy and change blocks", put in your start block and your end block the insert before block number, push "make changes" on the bottom of right of the screens column and you are all done. Just make sure you know where you are going to insert them or you will be learning to use the move function from the same page you started from.
    Bruce
    Nov 2006
    382
    I sell a manual! send me an email and I will sell you one. [email protected]
    Jetski (alias Tooling and Engineering Czar)
    "I may not have the keys to success.. but I have learned to pick the locks"
  1. Fanuc 15MF copying
    By stevo1 in forum Fanuc
    Last Post: 06-11-2008, 01:16 PM
  2. Dongle copying
    By JR1050 in forum Uncategorised CAM Discussion
    Last Post: 12-27-2007, 06:32 PM
  3. Toolpath operation copying
    By JWWalthall in forum Mastercam
    Last Post: 05-05-2007, 04:06 AM
  4. AutoCAD offsets and copying
    By skippy in forum Autodesk
    Last Post: 05-19-2005, 07:12 PM
  5. copying in Autocad
    Last Post: 04-11-2005, 02:55 PM
