603,897 active members*
3,373 visitors online*
Results 1 to 7 of 7
    Feb 2007
    317
    cornering tool path error
    I have a 3 axis vertical machining center with fanuc o-md controller. When the tool path is a small radius or a sharp corner at high feed (about 100 ipm) difference between programmed tool path and actual tool path is quite big. (about 1/32"). I know that a part of this error is caused by acceleration/deceleration parameter. But can i improve accurancy by changing servo tuning parameter. Actually, parameters are the same for all 3 axis. Loop gain 2500, proportionnal gain -816, integer gain 91. I have some notion in process regulation but i am a new with servo tunning.
    Mar 2007
    122
    Corner decel
    You might want to check your ACD(automatic corner decel), COV (automatic corner override), MDR (minumin decel ratio) parameters.
    Sep 2007
    49
    I've got the same problem.
    Jun 2006
    48
    do you know what motor model you are using??
    i could give some better suggestions if i knew
    its written on the motor itself, problably an alpha series the model will be followed by the alpha symbol
    you have to keep the values on the x,y the same or it will not cut strait
    try reducing the acceleration parameter until it starts overshooting,
    this is supposed to be done with an oscilliscope
    but i just put my hand on the table or the column and when you feel a jolt/vibration when it stops it usually means it overshooting then add small increments until it stops
    this will help reduce the corner rounding
    you should backup you parameters before you go messing with it
    Feb 2007
    317
    servo model is alpha6/3000
    -is automatic corner override active only in g41/g42 mode??
    -is there a parameter to set to activate automatic corner override or MDR???
    There is parameter #580 AOVLE (end point deceleration distance of automatic override at inside corner part. Set the operating range Le)
    and parameter #581 AOVLS (end point deceleration distance of automatic override at inside corner. Set the operating range Ls)
    Wath is difference between these two parameters???
    If ther is a very small radius in an inside corner, do the controller handle it like an inside corner??
    Jun 2006
    48
    #580 is the distance to the corner when its slows down at the reduced rate
    #581 is the distance after the corner before it speeds back up
    about the small radius yes only if the angle is greater than the value you specify in the parameter
    acd does only work in g41/42 and 1/2 tool dia for comp value
    it does not work if 0 is specified
    in order to get accurate high feed cuts you need controller with lookahead control
    yours might have it lok and c if the manual specifies a g08p1 to turn it on
    and a g08 p0 turns it off
    this function would control the error to a high accuracy regardless of the feed
    if not the next best thing is to manually slow the feed around small radaii and for sharp corners use the g61 mode
    Jun 2006
    48
    the 580 parameter value is with no decimal
    example value of '45' is .0045 inches/.045mm
  1. big position error in cornering
    By samu in forum Servo Motors / Drives
    Last Post: 01-30-2008, 04:30 PM
  2. Tool Path
    By cijunet in forum Mastercam
    Last Post: 11-26-2007, 04:17 PM
  3. Tool approach Tool Path
    By Kiwi in forum BobCad-Cam
    Last Post: 07-05-2007, 08:35 AM
  4. efficient tool path
    By balsaman in forum Mastercam
    Last Post: 07-28-2006, 05:37 PM
  5. Tool Path
    By WOODKNACK in forum Uncategorised CAM Discussion
    Last Post: 06-27-2003, 01:27 PM
