Hello,
I am researching ways to achieve micron tolerances on relatively small (under 50mm diameter) parts. This led me to come across, among other interesting ideas, to this very interesting product: an XY linear stage for microscopy applications. What drove my attention, besides the sufficient travel available and the supported max. load (50N ~/ 5Kg) was the advertised bi-directional repeatability, at 0.4um. They say this XY stage also comes equipped with a closed loop provided by 0.1um linear encoders, so this also helps.
What I couldn't figure out was how would this jewel handle the lateral forces encountered in regular milling operations.
Another idea would be to use it to guide, to a very high degree of precision, a mobile part against a fixed wire in a small EDM setup (I'm imagining it's easier to move a single, lightewight part, than to move the wire feeding jig).
Any ideas / thoughts on this one?
Thank you,
Eros
