I'm stuck, I can't get a 2d drawing recognized by MadCam. Madcam is very particular about recognizing the lines or curves in a drawing and I have not found a way to consistently get Madcam beyond the "select surfaces and meshes to export" command. I have received advice from Joakim and others and followed it exactly and not so exactly, I've spent many hours but no luck.
I know Madcam is a good and reasonably easy to use program but I think there is a piece of info that is being omitted in the advice I have received so
far. So if anybody would is up for a challenge send me your thoughts on how to get past the first step in producing a file in Madcam.
The advice I have already received from Joakim was to use the corner to corner tool to draw a rectangle around the part then click the select sufaces button in mad cam, this did not work. I also received advice to use the offset curves command and the corner to corner surface command this did not work either.
I really think there is some small piece of information that is being left out or for some reason I just have'nt gotten the description that works for me.
Thanks Joe
