603,945 active members*
4,083 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Creating simple geometry using a flat top scanner
    Sep 2004
    48
    Hello,
    I am curious of the possibility of using a flat top scanner to create 2D geometry for CNC programming.
    A freeware application is available to glean the linear dimensions from a part image created by a table top flat top scanner, commonly found in an "All in One", (scanner, fax, copier).
    Does software exsist to harvest the linear, as well as radial and angular dimensions?
    Small parts are hard to measure for reverse engineering, if you do not have an optical comparitor.
    I do not have a comparitor, or access to one.
    Being able to use the scanner I do have, would be a usefull tool for my small shop.
    Any ideas or thoughts on this one?
    Thanks in advance,
    Mike
    Jun 2010
    84
    I have had the exact same thought...
    Because a regular scanner is 1) precise and 2) planar, I think it would make a great reverse-engineering tool.
    I think that if you got some gauge blocks and scanned them, you could quite easily calibrate the scanner axes. It would be limited to mainly 2D objects but even that is useful. Given the resolution of today's scanners I bet you could get some reliable measurements with one.
    Aug 2008
    199
    scan and vectorize with illustrator or inkscape
    than export in dxf
    for CNC woodcarving - 3d puzzle - furnitures
    http://pagesperso-orange.fr/fabrun/
  1. creating toolpath for a simple impella
    By mortzs in forum Mastercam
    Last Post: 05-07-2010, 11:35 PM
  2. Adding laser scanner to 3dx microscribe or creating new arm
    By carbidecraters in forum Digitizing and Laser Digitizing
    Last Post: 01-14-2010, 03:21 PM
  3. simple problem creating depression in surface
    By George777 in forum Solidworks
    Last Post: 01-04-2010, 04:41 AM
  4. 100% flat table for flat bed lamination
    By Bernhardsen in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 08-24-2008, 02:31 PM
  5. Flat patterns from simple curved sufaces
    By jderou in forum Uncategorised CAM Discussion
    Last Post: 01-19-2007, 02:38 PM
