588,380 active members*
5,731 visitors online*
Results 1 to 1 of 1
    Sep 2008
    6
    Current sense problem
    Maybe I can't see the forest for the trees...
    I want to use the bridge circuit from UHU HP in another servo(modified Elm-Chan).
    Looking for two days at UHU schematic it seems to me it can work correctly only if it NEVER
    hits the current limit during positive level of PWM signal applied on pin 3 (CLOCK) of U6A(CD4013).
    I'am thinking to insert a XOR gate as frequency doubler (or two diodes )between PWM line and pin 3 of U6A to get true cycle by cycle current limit.
    Is this correct ?
  1. with Current Control & Sense Pin with L6203
    By Ahmed Adel in forum Stepper Motors / Drives
    Last Post: 06-17-2011, 12:07 AM
  2. Replies: 1
    Last Post: 07-06-2010, 05:35 AM
  3. Does it make sense?
    By vinybinder in forum Mechanical Calculations/Engineering Design
    Last Post: 06-24-2010, 05:42 PM
  4. how see the current resistance sense voltaje on osciloscope?
    By brutto in forum CNC Machine Related Electronics
    Last Post: 03-23-2010, 12:04 PM
  5. need help on sense resistor
    By xinzc28 in forum Open Source Controller Boards
    Last Post: 09-01-2008, 01:33 PM
