603,942 active members*
2,837 visitors online*
IndustryArena Forum > CAM Software > Vectric > Cut3D not seeing the BOX!
Threaded View
Barefootboy4 Cut3D not seeing the BOX! 12-11-2010, 12:22 AM
Teepaco Go back to step two in Cut3D... 12-11-2010, 04:13 PM
    Jun 2009
    113
    I'm new to Cut 3D and having a small issue I'm sure someone can help with. I'm trying to cut a model airplane wing. There is a upper and lower half. In cad I built the lower half in a BOX 12" x 45" x 3". The wing loft is flush to the top of the box. When I import to Cut 3D the box and wing mold look perfect. The problem is the finish cut preview wants to cut away all of the box right up to the wing loft and not leave the box. What am I doing wrong???
    Anyone out there who can help me out? I'm sure it's a simple fix. I've tried using various margins from "0" to 2" but nothing works.
    HELP!!!!!!!!!!!
    I have attached the DXF file for review
    Attached Files Attached Files
  1. Cut3D for Bridgeport Mill?
    By dirtdiggler in forum Vectric
    Last Post: 06-30-2009, 08:45 PM
  2. MeshCAM vs. Cut3D
    By henryj in forum Vectric
    Last Post: 06-16-2009, 06:09 PM
  3. Anyone have Cut3d problems?
    By CROSSHATCH in forum Vectric
    Last Post: 12-22-2008, 07:40 AM
  4. Cut3D and a Spiral Saw Bit
    By bsimages in forum Vectric
    Last Post: 07-06-2008, 09:48 AM
  5. 3D DXF with Cut3D
    By Switcher in forum Vectric
    Last Post: 04-25-2008, 11:46 AM
