It's been almost a year since you made your last post, so how are things going with the conversion? Can you give us an update of what you've done?
i, My hard drive died. I'm looking for the Superpro software for my dahlgren 300. Version 3~ preferred 3.5. Do you still have your machine or do you have the software? Thanks
Hi all, sorry for necro-ing this post but I wanted to share some backups of some versions of Dahlgren's software that I had access to.
Attached are WinImage images and dumped .zips of the original 3.5" floppy disks for:
Dahlgren SuperPro 3.10
Dalhgren CASDirect 2.1
I also have a copy of SuperPro 3.50 that was pulled from a machine, so not an original install disk but the program still seems to run fine.
I've also uploaded these to archive.org as a backup mirror: https://archive.org/details/dahlgren_winimage_images
SuperPro 3.x is intended to run on DOS. 3.50 seems to run fine on systems as old as 8088-based beasts (one of which is still in service miraculously).
I have noticed that the 3.50 install.bat doesn't seem to work, but you can simply run it via sp.exe
CASDirect requires Windows, at least Windows 3.x. I have not tested it with 9x.
I hope someone finds these files useful. I don't think there's anywhere else on the net where you can still get these.
