587,372 active members*
3,149 visitors online*
IndustryArena Forum > Other Machines > Engraving Machines > dahlgren/suregrave wizard 2000st help
    Dec 2012
    hi guys
    wondering if you lot could help i have been given the above engraver from a friend im using superpro 6 that came with it.
    i have no knowledge of cnc milling, ive been playing around and designing some plates every time it goes to cut out its going right through the plastic plate and into the aluminium base! ive adjusted depth in superpro to no avail
    and tried adjusting depth using the hand held controller to no avail always same depth.
    thanks neil
    Feb 2013
    The spindle that you are using with the cutter exposed should have a device called a nose which makes contact with the plastic and only allows the cutter to travel .003-.007 deep into the plastic depending on where you set the depth.
    Hope this helps
    PenTrophy
    In the Great NW!
  1. Dahlgren SCU
    By Loson in forum Engraving Machines
    Last Post: 01-21-2024, 09:10 PM
  2. Dahlgren System 300
    By phildunk in forum Engraving Machines
    Last Post: 09-14-2015, 05:17 PM
  3. Old Dahlgren Wizzard XL
    By Popeye in forum Engraving Machines
    Last Post: 04-19-2011, 04:42 PM
  4. Got my hands on a Dahlgren CNC router for $100
    By samim in forum DIY CNC Router Table Machines
    Last Post: 07-15-2009, 09:14 PM
  5. Nesting Wizard, Mach3 internal wizard.
    By thuffner3 in forum Mach Software (ArtSoft software)
    Last Post: 03-05-2007, 03:38 AM
