587,593 active members*
3,969 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > data server 16mc okk graphite mill
    Sep 2005
    164
    Could someone explain to me exactly how the data server and the network are supposed to communicate? I just got a second hand okk graphite mill with a 16mc control and a data server. I plugged it to the network and am missing something with regards to making it communicate. I have entered the ip address to the control... should this be the ip address of the computer? It asks for a directory as well, what format would that be? "D:\" where would I get the ":" key?
    Danny
    Sep 2005
    164
    data server = ftp but now how do i...
    How do I get colon ":" in the directory name on the fanuc 16-m control. I found where "string" should bring up special characters but it doesn't. The manual I found refers to param 0931-0935 as ascii for special characters... they don't seem to exist. the machine was built in 2000.
    The directory name should read "c:/okk"
    I have the ftp software up on the pc
    I have the name of the machine and password matching for each.
    (502)299-8675
    Danny
    Sep 2005
    164
    I got this figures out, there were a few things I was missing. Where the control was asking for a directory it was referring to a sub directory within the folder that the FTP software is setup to use, this was to be left blank if pulling from that directory.
    As for the colon ":" it was done by with use of substitutional characters in the parameter settings 0911-0916 using the ascii code. it was done as follows
    set the ascii code for the @ symbol in param 0915
    set the ascii code for the : symbol in param 0916
    then type the @ in the string where the : is needed.
  1. USING RS232 DPRNT W/DATA SERVER (18)
    By marcwdci in forum Fanuc
    Last Post: 03-29-2010, 05:36 PM
  2. Data Server with a Fanuc 18MB
    By buildyourown in forum Fanuc
    Last Post: 06-24-2008, 05:49 AM
  3. Data server question
    By npinto in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-09-2007, 10:47 PM
  4. VM1 Graphite Hurco Mill
    By loginname99 in forum HURCO
    Last Post: 08-21-2007, 03:08 PM
  5. Fanuc 18i with Data Server
    By Monty66 in forum Fanuc
    Last Post: 02-13-2007, 04:23 AM
