603,783 active members*
2,507 visitors online*
Thread: Degree wheel
Results 1 to 7 of 7
    Jan 2004
    190
    Degree wheel
    Does any one have a drawing or program for a degree wheel. I want to cut one on my cnc mill . I have downloaded some pics of some free drawings but have a problem getting them in my cad so as to edit and make the code , I have bobcad 20
    thanks Kenneth
    www.lambertsrc.com
    Jan 2005
    224
    What diameter wheel are you desiring?
    What resolution?
    Jan 2004
    190
    I want to cut one 4-6 "
    If I could figure out how to draw the scale would be even better
    thanks Kenneth
    www.lambertsrc.com
    Aug 2005
    90
    This is a 4", will this work for you?
    Attached Files Attached Files
    Robert
    Jan 2004
    190
    that will work perfect thanks and how did you draw this up?
    thanks Kenneth
    www.lambertsrc.com
    Aug 2005
    90
    I first drew two circles with X"0" Y"0", one was smaller than the other (1/4” or so), then I divided both circles into 360 parts (change > break > divide). I then changed colors and drew 5 join lines from the ends of the top arc segments the first one being the “0” or top line and then 4 more to the right of the circle at the end of each arc segment. When all 5 were done I selected by color everything except the lines (degree marks) and deleted them. Then I placed a point at 50% of the line on lines 2 thru 4, then trimmed the line to the point. You should have 5 lines drawn 1* apart from each other and 4 points on the center lines, removed the points, then select all. Then select change, then rotate and make sure it is by coordinates and around axis “Z” is 5 and the scale is 1, and “make a copy” is checked, in the number of copies type 72 and hit ok…hope this made sense and helps
    Robert
    Jan 2004
    190
    thanks
    thanks Kenneth
    www.lambertsrc.com
  1. how do i obtain required degree steps?
    By Syphonics in forum Stepper Motors / Drives
    Last Post: 01-07-2007, 11:43 AM
  2. 45 degree bevel on angle iron
    By Rypper in forum DIY CNC Router Table Machines
    Last Post: 11-14-2006, 07:00 AM
  3. Marking a degree wheel
    By tafc in forum MetalWork Discussion
    Last Post: 09-16-2006, 03:46 PM
  4. 90 degree radius bender
    By Scratch in forum Bending, Forging, Extrusion...
    Last Post: 09-09-2006, 06:57 PM
  5. 0.9 degree stepper. Use or not?
    By jdholbrook in forum Stepper Motors / Drives
    Last Post: 05-28-2006, 06:47 AM
