603,848 active members*
4,480 visitors online*
Page 15 of 15 5131415
Results 281 to 292 of 292
  1. #281
    Jun 2006
    36
    I just heard from Avnet and the bundle they sell in single quanities does come with the 3200cpi sensor.
    http://www.cypress.com/?app=search&s...ords=CYONS1001
  2. #282
    May 2007
    11
    Huge Bump...
    Not sure if this project has been round-filed, but I thought I would ask. Working on one myself. Just lurking for some thoughts...
    Thanks for comments and thoughts,
    Kevlar
  3. #283
    Dec 2010
    Question
    any progress with this?
  4. #284
    May 2003
    340
    Not from me at least, I lost interest, possibly because I don't need one.
    If I were to build one, I'd use the avago encoders, some decent bearings and a Parallax propeller microcontroller linked to a PC via USB emulating a serial port. Then some VB or python to get x,y,z from joint angles. In many ways it is a simple project, the difficulty is making it work really well and calibrating the arm etc.
    Just noticed some stuff about mouse sensors, a waste of time I think.
    Graham
  5. #285
    Jan 2009
    265
    I'm building an arm less precise, its a diy pantograph arm standing 90 deg with a ball bearing tip on one side and a laser mouse on the other end. It will have an x axis slide for taking contour slice intervals, its mainly for surface work, 'streaming' splines for 3d modelling. It's only accurate to about 0.2mm, still, it gives me splines instead of mesh or point clouds which saves hours of cad work.
    (i really hate mesh!)
  6. #286
    Oct 2007
    Interesting thread even if old (like me). I have not read the entire thread, but think I got the gist of it, and have a question.
    Instead of having to put up with the accumulated error of several circular position encoders, why not track directly, and in an absolute manner, the position of, say, the head of the stylus? Then the only additional information required to determine the position in 3D space of the tip of the stylus, would be the position of the tip with respect to the head of the stylus.
    Of course I have assumed that the head of the stylus is more easily trackable directly than is the tip, or I would have suggested tracking the tip directly.
    One simple way to track the head would be to locate an LED there. This is just an example, as the LED would probably not provide sufficient accuracy.
    I know there are various inexpensive and accurate techniques for 3D scanning (e.g. photogrammetric techniques) that would allow determination of the 3D position of the LED (or whatever point we chose as target).
    Perhaps this idea has already been explored? If so I would be interested in a pointer.
  7. #287
    Aug 2012
    10
    I tried direct tip tracking back in the day and ran into a couple of problems. At the time the tolerance was not good, this may no longer be the case. LOS is the big show stopper. Basically any complex enough part will have line of sight occlusions even if you paper the area with cameras.
  8. #288
    Jan 2009
    265
    Quote Originally Posted by vicen View Post
    "Of course I have assumed that the head of the stylus is more easily trackable directly than is the tip, or I would have suggested tracking the tip directly."
    I like your thinking, a mini gps system.
  9. #289
    Aug 2012
    10
    Nice, my order of posts reversed and I managed to reply to 10 year old post in this thread... sigh.
  10. #290
    Jan 2009
    265
    Tell me about it, this website is falling apart.
  11. #291
    Feb 2006
    174
    Old thread yeah, but there is some good stuff in it.
    Direct tracking via leds and cameras is the principle of the Metronor system.
    Metronor CMM - Next Generation Portable CMMs
    Lars
  12. #292
    Feb 2006
    68
    Re: Digitizing arm options
    Hi; I got a old Faro , that i would like to play with it , it does not have any cables to connect to a computer, or to a power supply
    also it does not come with any software . Graham S, I know that this thread is about 20 years old , but if you can share with me to the software that you developed for this project It will be very much appreciated
    as most of the download links does not work
    thank you
    Rasta
  1. Digitizing
    By carlboe in forum Tormach Personal CNC Mill
    Last Post: 01-19-2012, 02:47 AM
  2. DIGITIZING
    By morvaman in forum DynaTorch
    Last Post: 11-05-2010, 04:20 PM
  3. digitizing
    By 70cyclone in forum Milltronics
    Last Post: 11-26-2007, 01:40 AM
  4. Digitizing in AUS???
    By member login in forum Digitizing and Laser Digitizing
    Last Post: 07-24-2007, 06:03 PM
  5. Digitizing
    By Michael M in forum Centroid CNC Control Products
    Last Post: 01-18-2005, 10:14 PM
