587,833 active members*
3,647 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > Dinosaur skeleton, and other models, DXF files.
Page 129 of 224 2979119127128129130131139179
Results 2,561 to 2,580 of 4471
  1. #2561
    Mar 2007
    463
    Quote Originally Posted by taawint View Post
    hello all
    March 8 happens if someone can victoriser this image in dxf
    thank you
    It may need a little cleaning up, but here you go.
    Larry
    Attached Files Attached Files
  2. #2562
    Oct 2010
    hello all
    thank you
    Here is one , you have to clean it yourself.
    Hope you can use it.
    CNC 6040 Router Engraver
    Mack 3
  3. #2563
    Oct 2009
    25
    wanted: Lighthouse 3D Puzzle
    Hello,
    does someone have a drawing of a 3D Lighthouse puzzle?
    Thanks,
    Klaus
  4. #2564
    Oct 2006
    69
    Quick question. Do you have to adjust the slots on the 3d puzzles for the thickness of the material you are using? Common sense says yes.
  5. #2565
    May 2007
    60
    Smile
    Quote Originally Posted by skipper_52 View Post
    Quick answer - YES
  6. #2566
    Easiest way Skip is to resize the whole puzzle until the slots match your material.
    Basically divide the slot size you want by the slot size you have to get the scale then use that as your scaling factor. (4 divided by 3 = 1.33333333) then scale by 1.3333333 (the reverse method also works for making things smaller)
    Changing just the slots unless you know a bit about drawings and fit will mean some parts may not go together (they interfere with each other)
    best wishes
    Dave
  7. #2567
    Mar 2006
    118
    I thought that the reason to use slots was to use a bit that is the same size as the material. Wouldn't this eleminate having to scale the work.
    Chuck
  8. #2568
    Hiya Chuck,
    If the slots were centre lines that may work but once you move into 3 dimensions the relative fit between two parts is as critical as the fit from one part to another. Or picture it as thickness becomes a 3rd dimension.
    best wishes
    Dave
  9. #2569
    Apr 2008
    125
    Map Holder Pinoccio
    Map holder Pinoccio 100% cleanly, 2 mm wood
  10. #2570
    May 2011
    My own small Dollhouse
    My first piece for this great forum. Maked from 6mm MDF and some plexiglass..
    Enjoy!
    PentueR
  11. #2571
    Apr 2003
    550
    Quote Originally Posted by Maccarly View Post
    Maccarly
    Looks great..
    However your zip file is corrupted...
  12. #2572
    Apr 2008
    125
    Pinoccio
    Hier as Vektor-PDF-File
  13. #2573
    Apr 2008
    125
    Key Board
    Material 18 mm Wood
  14. #2574
    Apr 2008
    125
    Key Board Camper
    Key Board for Camper
  15. #2575
    Oct 2010
    Here is a dxf of Pinocchio and a derivative of it with a dragon on it.
    Hope you like it
    Mack 3
  16. #2576
    Oct 2010
    Here is a small table you can pull in over the sofa, even in the corner if you want to do to the opening in the middle.
    Hope you like it.
    Attached Thumbnails Attached Thumbnails 131_Serendip_C-side_1.jpg   43642_Serendip_C-side_1.jpg   43642_Serendip_C-side_2.jpg   43642_Serendip_C-side_3.jpg
    Mack 3
  17. #2577
    Feb 2012
    I find these D-Torso models
    Hello friends, Could anyone, who has these models, upload them?
    Thanks in advance
    Hola amigos, es posible que, alguien que tenga estos modelos en formato dxf, los pueda subir?
    Gracias por adelantado
  18. #2578
    Apr 2003
    550
    That worked thanks..
  19. #2579
    Oct 2010
    Letters
    Testing out the machine and software to find out how much you can do on it, and how many different letters and backgrounds one can make.
    Here are the first 5 items, hope you like them.:wave:
    Attached Thumbnails Attached Thumbnails A_B_C_D_Hazard_04.jpg   A_B_C_D_Hazard.jpg   A_B_C_D_Hazard_02.jpg   A_B_C_D_Hazard_03.jpg
    Mack 3
  20. #2580
    Oct 2011
    69
    need help
    Does anyone have the Chicago bears logo in a dxf file a friend wants one made up
  1. Dinosaur Puzzle
    By Rosey Musick in forum Machine Created Art
    Last Post: 04-11-2013, 07:03 PM
  2. Dinosaur Trade
    By roninB4 in forum Diemaking / Diecutting
    Last Post: 11-18-2012, 03:01 PM
  3. Who will stop this china Dinosaur??
    By smtclman in forum News Announcements
    Last Post: 12-19-2010, 11:05 PM
  4. Epoxy Granite "s Skeleton
    By hkxy in forum Epoxy Granite
    Last Post: 05-03-2010, 02:35 AM
  5. Replies: 2
    Last Post: 03-09-2007, 08:47 PM
