603,352 active members*
3,426 visitors online*
Page 60 of 109 1050585960616270
Results 1,181 to 1,200 of 2171
  1. #1181
    Aug 2006
    2758
    Quote Originally Posted by contactirfu View Post
    Kreutz / L98FIERO how do the "Differential quadrature encoder interface" work, are they similar to these:
    Yes, but I used the SN75115N differential line receiver instead of the other chips, and this one is mounted on the main pcb instead of being an "add on" board.
  2. #1182
    Aug 2006
    2758
    Quote Originally Posted by L98FIERO View Post
    Kreutz;
    When you get the design finalized will you make a description of how to build and test the board for people like myself that are not as familiar with electronics but want to build the board themselves. ......
    LaVerne
    I will do my best to provide enough information
    Regards,
    Kreutz.
  3. #1183
    Jan 2005
    1050
    Quote Originally Posted by kreutz View Post
    Then what should be on the motor end, considering i have US digital encoders the cheapest ones, or can u suggest what encoders to buy if i use your new pcb...preferably US digital! (easy to order)
    Regards
    IRfan
  4. #1184
    Nov 2006
    17
    Regards
    IRfan
    Presumably, you can use single-ended encoders by just tying one of the inputs (-) to ground.
    Cheers,
    Allan.
  5. #1185
    Jan 2005
    1050
    Quote Originally Posted by Dibblah View Post
    Cheers,
    Allan.
    Allan,
    My poor brain cant understand, can you elaborate......ie.,explain a bit.
    Thanks in Advance!
  6. #1186
    Nov 2006
    17
    Single ended encoders are the type you get if you don't ask for differential.
    On the new UHU board, I'm assuming that you'd just connect the encoder to the + differential input and connect the - differential input to ground (0v).
    Cheers,
    Allan.
  7. #1187
    Jun 2003
    242
    differential encoders
    The differential encoders have 8 wires, a plus and a minus for the a, b and index plus 5v and ground. Some one can correct me if I'm wrong or maybe contact US Digital but I think you may be able to get the tiny LD5 board that I had a picture of in my last post and connect that to each of your single end encoders. My understanding of the 26C31 chip is that it doesn't change the signal but adds an 'inverted' copy of the existing one and then the receiving end converts it back to the original signal. My guess is that you get twice the difference in voltage and therefore a 'cleaner' or at least easier to read signal. If you don't have an index mark on your encoder it obviously won't add one.
    LaVerne
  8. #1188
    Aug 2007
    -------wrong user----
  9. #1189
    Aug 2007
    I am sorry, I was visiting Mr. RCruz and posted twice on this forum from his PC, didn't realize it was under his user name. It won't happen again.
    Kreutz.
  10. #1190
    Aug 2006
    2758
    LaVerne
    Adding a differential transmitter chip (for those who have a single ended encoder and want to use the differential transmission advantages) is easy, I am sure there are a lot of boards readily available, or you can make your own. The receiver I have on board can be left unpopulated (if you don't use differential encoders), and connect a couple of soldered jumpers for your single ended (standard) encoder.
    The advantage of using a differential encoder is that it rejects common mode noise, so the signal is cleaner, and the encoder cable could be longer.
    Kreutz.
  11. #1191
    Jan 2005
    1050
    Kreutz.
    I understand Kreutz, my problem was that I already have a few single ended encoders with me and my cable length is long. COuld you or anyone suggest me a suitable pair(easily available and widely used) in dip package like the one I posted in my earlier post. I just wanted to know whats the IC(transmitter) on the motorside,
    I thinkl its easy to build one on a general pcb than order one and wait!
    Regards
    IRfan
  12. #1192
    Jun 2007
    3
    hello to everyone,
    thanks all of you for what you are doing here. I am really a newbie to cnc. I have been using large plotters and a small roland mdx 15. I have spent a lot of time for deciding to build up a cnc router. I think servo dc motors and UHU drivers ( or controllers?) are the best solution for me. I just hope to build a small prototype first with the salvages i have been collecting for years. I have 3 dc servo motors from dynetic systems with 24 volts and 3.3 amp. The point is that these motors have only 2 cables and a separate ground cable. But when i check the schematics and pictures from you i see that there are more than 2 connections. Do i need an extra thing ? Is it an encoder ? Or is it ok just with these dc motors. please help?
  13. #1193
    Aug 2006
    2758
    Quote Originally Posted by gilgamesh View Post
    hello to everyone,
    A servo motor is not just the motor, it needs a feedback device. Depending on the application, the feedback device could be a tacho-generator, a resolver, potentiometer or quadrature encoder. If you have a DC motor with just two wires it is probably either a universal motor or a Permanent magnet brushed motor.
    One of the most used encoders for positioning servos is the quadrature encoder. They have a minimum of 5 cables: DC return, Vcc, Channel A, Channel B and Index (some of them don't have the Index feature and might use only four wires). Differential encoders include the CHa-, CHB- and I- wires.
  14. #1194
    Aug 2006
    2758
    Regards
    IRfan
    You could use any differential line driver IC with 5 Volt VCC, like the uA9638 type (dual), if you also use the index channel you can use a quad differential line driver chip. Remember to use twisted pair cable for each differential pair.
  15. #1195
    Jun 2007
    3
    Thanks Kreutz,
    Where can i find information about connecting a dc motor to a quadrature encoder? can i connect any dc motor to quadratures?
  16. #1196
    Aug 2006
    2758
    Thanks Kreutz,
    To find out what are the best motors for servos read this: http://www.uhu-servo.de/servo_en/UHU%20FAQ_en.pdf
    For adding the encoder to a DC motor read this: http://truetex.com/servomod.htm
  17. #1197
    Jan 2005
    1050
    Thanks Kreutz,
    http://www.usdigital.com/products/products.shtml would be a good start.
  18. #1198
    Feb 2006
    65
    You could also check http://truetex.com/servomod.htm.
    "Good judgement comes from experience, and a lot of that comes from bad judgment." - Will Rogers
  19. #1199
    Jan 2005
    1050
    kreutz found out some neat data at usdigital
    http://www.usdigital.com/data-sheets...0Schematic.pdf
    Do you think these will work?
    Regards
    Irfan
  20. #1200
    Aug 2006
    2758
    Regards
    Irfan
    They will work.
  1. Central PID Controller vs. PIV Controller in each Servo Amp
    By Bronx68 in forum CNC Machine Related Electronics
    Last Post: 11-20-2013, 05:33 PM
  2. Servo Controller pin out ?????
    By slowtwitch in forum Servo Motors / Drives
    Last Post: 05-28-2013, 03:55 PM
