587,143 active members*
4,900 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Doosan Z290SMY turret problem
    Oct 2008
    Cool Doosan Z290SMY turret problem
    I have crashed with the upper torret in B axes. The turret has rotated for around 10 degrees. Is it possible to rotate the turret with wheel and how?
    look at your electric door, if there is a blue book with the machine
    in the book stands KEEP RELAIS, there is prob. one for manual turret turing.
    some versions you can rotate the turret when its powered up, rotate the turret and hit the emerency button, turret will stand out and can be hand turned.
    turn the turret bij hand to a position, set the promotion driver to the same position as your turret is. and that should be fixed.
    you also need to line up the turret again, and check the b-axis, cut a piece of metal and check it's not tapered
  1. HAAS SL-20 TURRET PROBLEM HELP
    By allmotormatt in forum Haas Lathes
    Last Post: 01-20-2011, 06:47 AM
  2. Turret Indexing Problem SL4
    By ndp in forum DNC Problems and Solutions
    Last Post: 06-30-2009, 04:39 PM
  3. doosan fanuc 18t turret
    By julio_gyn in forum Fanuc
    Last Post: 05-19-2008, 06:43 PM
  4. SL 10 turret problem
    By PBMW in forum Haas Mills
    Last Post: 08-16-2006, 02:51 AM
  5. Mazatrol T32 Turret Clamping problem
    By sunrock_83 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-08-2006, 05:38 PM
