Re: DYN4 Overcurrent, but only on initial startup
Originally Posted by
mactec54
I believe the problem is with the oak or how your wiring circuits are, I have installed dozen's of these drives and have never had any of these problems, I have never used an Oak system, I know others have had problem getting the Oak setup as well, they are a good system once you get it sorted have you had any help from centroid
Have you installed any with analog/torque mode control? I had exactly the same problem, but did not seem to have the problem when configured for step & direction. I need to get one on the bench and really understand a bit more about the logic and settings.
Jim Dawson
Sandy, Oregon, USA
