Originally Posted by
mike sr1
It only drops .040 approximately, it isnt very noticeable unless its cutting horizontally, then when the e stop is pressed the head will drop at the instant the brake engages, and it produces a nice gouge in the part.
This happens each time the e stop is used, I know it does this so I use the esc key to just stop the machine, but in z down that will let the head freewheel.
I will call Tormach today and see what they have to say about it, may just need to tighten the gibs a bit more.
If its not a common problem, then I would think it would be mechanical as the dro reads the same before and after the gouge.
