Ok the manual has finally made it from the machine back to my desk, unfortuneately the last 6 months have been the bussiest of my life once i get time i will scan it and post it up
Search this forum: I have posted link to my online cc of manual more than once....
here is link yet again:
https://app.box.com/s/t84rxtbkz82vtlhmv4xk
147 pages. enjoy.
Hi, I need U12 RAM content .PM030BS4075RH-0 9105-0009-002 Could anyone read and send me bin please?
I have bad checksum.
Regards
Hi, this is the link with the bad file,ayone knows where is checksum?
https://1drv.ms/u/s!Ag5s11mpTf5CgZxn37o7egd2NHpWWA
Regard
I have U12 8kbytes DS1225 RAM PM020BS3016NH-0X with bad chechsum , I would look for a kind person who could post / post me the .bin copy of this or even another similar version
I understood these things about the code on the backed ram:
PM020BS3016NH-0X
PM = PERSONALITY MODULE
020 = 20AMPERE
BS = ??
3016 = MOTOR FRAME H3016 Electro-Craft
N = MOTOR WINDING KE V/krpm DESIGNATOR
H = OPTICAL ENCODER 2000 LINE COUNT(STANDARD)
-0X = ??
The letters BS and 0X what could they mean?
It seems that whatever what I do, I "can't save to personality module". Does anyone also have this problem or have a solution for it?
I also only managed to make the motor turn in one direction, whatever the states of the FAC or RAC inputs.
Hi everyone, here's what I know about this drive:
P1-1 and P1-2 have to be shorted for the drive to be enabled.
P1-3 (-) and P1-4 (+) controls the speed of the motor. You have to give it a 0-10V signal to control it. Note that there are PWM to 0-10V converter out there (about 5$) that could be use to use a simple microcontroller to control it.
P2-1 and P2-2 have to be shorted to turn in clockwise direction
P2-3 and P2-4 have to be shorted to turn in counter-clockwise direction
P5-4 is used to control the current limit with a 0-10V signal
To control/test/troubleshoot the drive, you have to set up the jumpers P11 (2-3), P12 (2-3) and P13 (1-2) to RS-232 mode. Use Hyperterminal, COM1 (your serial port from your computer), full duplex, 9600 baud, parity none, data bit 8, stop bit 1, Xon Xoff,
You have to put P10 jumper to position 2-3 to be able to save your tuning to personality module (Never move that jumper when the drive is powered)
