What kind of amp draw do you get for power off of a USB port?
Another thought on LED's. I didn't use them, but may make more switches that do, you must consider what your source voltage is going to be. If you are using a G540 input line for the 'input' of the switch, it is 12v, so you will need a bigger resistor to knock that down or you will instantly fry most LED's by sending 12 volts through it.
Here is an online calc for figuring out what resistor you need. Put in supply voltage (12v for G540), drop across the LED (ie, it's operational voltage), and LED current (what it will draw) and it will tell you what resistor you need.
R = (Vs - Vl ) /I
How to calculate resistance in ohms
