Re: Electronic home switches made easy!
Ray,
As Rick has said, you can use both hall and mechanical switches. It would be best to use the hall for homing because of their accuracy. Then use the mechanical as the limit if you so desire, as a limit doesn't require much accurracy at all.
The hall effect switch can be wired as normally closed or normally open depending on the electronic design. They can also accept any voltage you desire to use them with, if designed with an optocoupler or optoMOS.
I have designed my switches with an optoMOS and you can run up to 60v through them to switch, but they would require a 5v source to power the LEDs and the sensor. I have also designed my switches to be selectable for normally open or normally closed operation.
So running a control board (i.e. G540) that puts out 12v through a mechanical switch, will also work with a hall switch if designed in similar fashion as mine have been.
X²Design&Fabrication
www.x2df.com
