588,568 active members*
4,801 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Endmills for cutting splines
Results 1 to 6 of 6
    Apr 2004
    353
    Does anyone know a place that sells endmills for cutting splines? Seems to me I've seen somewhere but I cant recal.
    The drawing calls for:
    16/32DP
    30 Deg PA
    1.750 Major Dia
    1.589 Minor Dia
    27 Teeth
    Looks like an involute style.
    I need and endmill since I am making this part on a VMC, also it is very close to a shoulder.
    Thanks for any info
    Feb 2009
    32
    Could you put a hob on arbor and run this? Not aware of a standard endmill to do this? Heck...... that's why I visit this site though, I always keep learning! I am sure you could find some kind of a hob with those demensions required and run it off an arbor in a e/m holder and side machine it.
    Mar 2006
    474
    Using an endmill and cutting right on your centerline, you won't get a radiused minor diameter. I suppose you could index the shaft so each spline flute is vertical, and side mill them, and at least get a faceted minor diameter.
    Mar 2003
    4826
    Is this a production situation or a one off?
    I've never seen any commercial offering of endmills that will do this. I can well imagine the extreme delicacy of the tip of such an endmill, resulting in a short useful life for the tool.
    I would side mill it. For a single job, grind up a flycutter and make a little arbor to hold it in a regular endmill holder. However, grinding the tool requires a sample spline to test the tool shape. If you have a male spline sample, you can cast an inverse off of it with a bit of plaster of Paris, then you've got a gauge to grind and fit the tool to.
    For production, you could likely get a tool grinding shop to custom make the tool, using something like a woodruff cutter as a basis to begin from. A small woodruff cutter might get you within 3/8" of a shoulder. If you must get closer to the shoulder than that, you'd almost be looking at some sort of EDM procedure.
    First you get good, then you get fast. Then grouchiness sets in.
    Mar 2006
    2712
    You can cut on the side of the part with a form milling side mill or end mill.
    www.tmfmllc.com www.ashgear.com Ash might rent one if it's a short run or one-off.
    Dick Z
    DZASTR
    Apr 2004
    353
    I ended up getting one custom ground for me. It is for a one-off job. I had to go with an endmill since the splines stop very close to a chamfer. Minor diameter is not a big deal, they just need it to fit nicely in the female socket. Thanks for he help
  1. cutting splines??
    By inthedark in forum Uncategorised MetalWorking Machines
    Last Post: 04-29-2009, 04:07 AM
  2. Cutting Internal Splines?
    By Krusty Karl in forum MetalWork Discussion
    Last Post: 11-12-2008, 06:32 PM
  3. cutting splines with mill
    By astro in forum Uncategorised MetalWorking Machines
    Last Post: 08-19-2008, 12:55 AM
  4. Feed rate? Slot cutting with 0.031" endmills?
    By Donkey Hotey in forum Haas Mills
    Last Post: 03-27-2008, 07:24 PM
  5. Help with splines
    By CNCRob in forum Autodesk
    Last Post: 09-03-2005, 09:14 PM
