Hi Harryn.
I, too, am looking at using this approach to "true" up the surface of component pieces.
The only idea I can offer is along the same lines as yours, of multiple pours, but how about doing a quick brush coat on one side of the component, then turn it over, drop it onto whatever jig you've set up to get it level, then do the "table-top pour" on the other side.
While this reduces the warping stress, familiar to people veneering panels, what I can't figure out is what happens when you do the second pour over the brushed coated side to true that one up ?
Perhaps the only answer is to always fabricate anything that needs two opposed but true faces from two layers with their bad sides inwards.
On second thoughts, is this really a problem, given the difference in bulk of Larry's channel and that of the resin coating ?
John
It's like doing jigsaw puzzles in the dark.
Enjoy today's problems, for tomorrow's may be worse.
