603,894 active members*
2,695 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > fadal, inconsistent fixture offset, using A-axis
Results 1 to 5 of 5
    Sep 2009
    93
    guys,
    I'm not a Fadal expert and nether is our operator.
    we have had numorous errors regarding the y axis fixture offset being centered to the a-axis. most recently, the offset has gone from y-.035 to now y+.026!! all other axes have been consistent.
    as i'm not at the machine much, im having trouble figuring out what is going wrong. mechanical (only two bolts holding rotary) or control operation error or a problem with the machine (bad CS switch).
    the operator claims to send the machine home at night and CS in the morn the same everyday.
    the manual lists multiple coordinate systems, why?
    1. machine coordinate sys
    2. tooling coord sys
    3. fixture offset
    4. program coord.
    is there a page where one can see, machine pos, absolute pos, distance to go etc.. like a normal mill????
    N94850 G94 Z7.7527 F20.
    N94860 M5
    N94870 G90 G0 H0 E0 Z0.
    N94880 M1
    N94890 ( 3/4 FLAT ENDMILL TOOL - 20 DIA. OFF. - 20 LEN. - 20 DIA - 0.75 )
    N94900 T20 M6
    N94910 G0 G90 S3500 M3 E1 X-7.075 Y0. A-327.11
    format 2, btw.
    if the a axis was at E1 A0 before the tool change shouln't it still be there after (but bufore reading new a location)???
    Jul 2009
    317
    Every time the machine is CS (cold Start) will ask *Want to go to the last home position?
    If the home position is a the CS (all axis at the marks), the machine is not going to
    move. Normaly E1 is XOYOZ0A0B0, After moves to a given FIXTURE OFFSET, that would be your new Home position.
    1. machine coordinate sys -from the cs position to the travel limits
    2. tooling coord sys-Tool table
    3. fixture offset- to stablish a new program or part position
    Here (don't know the E1) suppose is X3.Y3.A90; all 3 axis will move to that position
    after readind the E1..
    Aug 2009
    1573
    If you are doing any heavy milling or semi heavy you should use a knee bolted to back of A Axis if possible. Sounds like it is moving.
    Good Luck.
    Jan 2004
    3154
    There are no CS switches.
    The operator uses eyeballs and alignment marks.
    Typically an incorrect CS will be off by a substantial amount (1 rev of the ballscrew).
    www.integratedmechanical.ca
    Sep 2011
    hello every one,
    I am using Chmer CNC Machine...Need help about removing the memory card from the machine....Coz everytime I do that, it hangs...No other solution for that, besides from turning it off. And start all over again...What is missing before removing it????
  1. Macro and Z fixture offset
    By Techman in forum Fadal
    Last Post: 08-06-2009, 07:56 PM
  2. Mirroring a fixture offset on a CNC-88
    By CaseyCAM in forum Fadal
    Last Post: 07-25-2009, 07:24 AM
  3. G54.2 DYNAMIC FIXTURE OFFSET
    By KBLANKE in forum Mori Seiki Mills
    Last Post: 06-16-2009, 03:40 PM
  4. Creating a Fixture Offset
    By robmints in forum Mastercam
    Last Post: 09-01-2008, 05:20 AM
  5. NX5 Fixture Offset
    By H234 in forum Uncategorised CAM Discussion
    Last Post: 03-27-2008, 02:12 PM
