587,189 active members*
2,688 visitors online*
Results 1 to 9 of 9
    Sep 2006
    126
    Fanuc 10M Parameter input
    Dear All,
    I am facing problem on Kuraki horisontal Mill (Fanuc10), the first time i got alarm Ram Parity Error, and i have initialized.
    please somebody help me, how to input parameters by RS232?
    i have back up on punched tape but the machine doesn't have tape reader.
    can i read tape data on other machine first and save to NC data?
    Thanks for help
    Dec 2008
    239
    if you have hard copy of data than you can put manually or you can attach any other fanuc tape reader with your machine If you want to know more mail on [email protected]
    Apr 2009
    1379
    the option parameters have to be input in IPL mode. Do you have a these on paper?
    Bill
    Apr 2009
    1379
    also, the PC parameters have to be input manually (cn not be done through the tape reader or serial port). Do you have those written down?
    Bill
    *~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
    *__________If you feel inclined to pay for the support you receive__________*
    *_______Please give to charity https://www.oxfam.org.au/get-involved/_______*
    Jun 2008
    1511
    Nastek,
    If you initialized the control then you will have to reenter everything. First thing you have to do is power on into the IPL mode then enter your option parameters in hexadecimal format. You then have to enter your communication parameters so you can communicate via RS232. Now you can download your parameters. Now you have to hand input your counters, timers, keeprelay data. Last you can do your programs.
    Here is a thread that explains the most of the details to do the above. Let me know if you have any questions.
    http://www.cnczone.com/forums/showth...ht=hexadecimal
    Good luck,
    Stevo
    He needs to get the parameters off the punch tape first !
    Quote Originally Posted by stevo1 View Post
    Nastek,
    Good luck,
    Stevo
    Sep 2006
    126
    Thanks guys, for help me, i have input parameters, and machine working well.
    Regards
    Nastek
    May 2009
    181
    next time you need to do a reset and delete,
    then input your 900 parameters at once ( dont turn off machine till they are all in)
    then set up your rs232 parameters and load the machine
  1. Mazak T2 parameter input format?
    By nervis1 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-25-2023, 04:39 AM
  2. Fanuc 7M parameter input
    By greenery_fr in forum Fanuc
    Last Post: 05-27-2009, 02:13 AM
  3. Meldas M0- cannot input xyz axis parameter
    By Place2809 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-22-2008, 05:55 PM
  4. PC input/control with Fanuc 5
    By jevs in forum Fanuc
    Last Post: 10-22-2008, 03:49 AM
  5. Fanuc O-MB incremental input
    By MPE racing in forum Fanuc
    Last Post: 05-22-2003, 08:46 PM
