603,344 active members*
3,443 visitors online*
Results 1 to 5 of 5
    Nov 2007
    29
    Fanuc 10M will not let program download.
    I bought a use Takisawa MAC2 with 10M Fanuc control.
    Tried to download a program, no alarms. It will punch out to the PC.
    i have checked the cable and parameters and still no download.
    Is it possible to get a aftermarket port to upload programs even if something wrong with the punch board??
    I have a fanuc 10T, and I read programs this way...
    I hope this helps
    first I go to the PROGRAM, then READ, then there is a PROG# and here you write down the number you want your program to be, basically the same you do have after your O, and then you press EXECUTE. After that you go to your computer and send your program.
    Make sure you have all the pins in your cable right and also the terminal parameters.
    Good luck
    jlankenau
    Quote Originally Posted by rchunter94 View Post
    Mar 2003
    2932
    What software are you using to communicate? Is it configured to "wait" for the CNC?
    Have you tried sending the same program you just downloaded to the PC back to the machine?
    Do you have % signs at the top and bottom of the program?
    Does LSK blink when you try to read?
    Oct 2006
    9
    Post same machine ,same control
    it´s there message right after the larm came up.
    it has to be (bge 807) go to paramerer and chaged to com 2 or in your pc set up com 2 instead of com 1 and That should work.
    Nov 2007
    29
    Jose,
    can you send the parameters that are loaded for these numbers that relate to rs232c.
    20
    21
    22
    23
    5010
    5011
    5012
    5013
    etc.
    Thanks, PC only has COM port 1.
  1. Replies: 12
    Last Post: 05-09-2023, 09:01 AM
  2. fanuc 0l download problems
    By edgegauthier in forum Fanuc
    Last Post: 02-10-2008, 11:27 PM
  3. Replies: 9
    Last Post: 11-06-2007, 03:29 PM
  4. FANUC 6TB Unspecified Alarm on Download
    By smithy2167 in forum Fanuc
    Last Post: 08-15-2007, 03:14 AM
  5. Fanuc 18i Comms Download & Upload
    By Mr_Carpyman in forum Fanuc
    Last Post: 06-26-2006, 07:14 PM
