587,853 active members*
3,599 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Fanuc 11-T CNC lathe center programcode
Results 1 to 4 of 4
    Jan 2006
    21
    Question Fanuc 11-T CNC lathe center programcode
    Hi FriendsFanuc 11-T CNC lathe center Threading cycle G76 some code I don't know, please explain and help me.G76 X4.378 Z-5.5 I0.4666 A0.128 K60 D00300 F0.25;G76 ( Threading cycle )X4.378 ( Starting X 4.378 )z-5.5 ( Thread cutting upto 5.5" Deep )I 0.4666 ( Taper thread, Diameter difference upto 5.5" deep is 0.4666 )A 0.128* / A - What is meaning ? I don't know , I need help this code.K 60 / K 60 What is meaning* ? and How using in G76 ? I need help this code.D 00300 / How use D 00300 in G76 Threading cycle? I need help this code.F 0.25 ( Thread 4 TPI )Please clear above code* A0.128 / K60 / and* D00300 in G76 Threading cycle.Thanks and Regards,Manoharan.
    Jan 2006
    21
    Help me someone above my thread.
    Dec 2003
    24220
    Do you not have the Fanuc operator manual? It explains it all in there.
    Al.
    Albert E.
    Jan 2006
    21
    Quote Originally Posted by Al_The_Man View Post
    Al.
    First thanking you very much for reply. I do not have operator manual. I will try to get operator manual.
    Thanks and regards,
    manoharan.
  1. Replies: 2
    Last Post: 08-22-2008, 05:14 AM
  2. Crashed my lathe, now tool is above center
    By protrxrptr17 in forum Uncategorised MetalWorking Machines
    Last Post: 04-24-2007, 03:22 AM
  3. Using lathe center
    By linesman 71 in forum G-Code Programing
    Last Post: 03-24-2007, 09:49 AM
  4. Revolving Center on Twin Spindle CNC Lathe
    By Joey in forum Community Club House
    Last Post: 01-06-2007, 01:15 AM
  5. CNC Lathe&Machining Center which ones to get?
    By kanankeban in forum Uncategorised MetalWorking Machines
    Last Post: 06-16-2005, 10:04 PM
