587,989 active members*
4,887 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 18m for a Quickmill 3 axis gantry machining center
    Jun 2008
    Unhappy Fanuc 18m for a Quickmill 3 axis gantry machining center
    Hello all, I'm new to this forum and was hoping for a little assistance. I am drilling about 6 inches of stainless steel baffle stock and with the available inserts for the drill body I'm using it is causing a heavy chip load about halfway through the stock, regardless of my feeds and speeds. I would like to use multiple dwells on each hole and was wondering if this is possible and if so how to program it in. Thanks for any help.
    Nov 2007
    361
    Talking programming
    If you have the print send it to me and I will program using a g04 after each z- move peck drill but with go4 after each peck write back with more info.
    ps If you need any thing programmed just give me a call or e-mail I have my own cad software I dont charge much ha hahahahaha
    Aug 2008
    Hello all, I've Fanuc 21M on Excel CNC machine. Now, I can't use it for RS232 interfacing, because of lsk message. Please give good reply to me.
  1. RTCP (For Fanuc 18i Controller) five axis machining
    By Ravasaheb in forum CNC Machining Centers
    Last Post: 07-05-2010, 10:26 AM
  2. new to cnc machining center
    By BruceinOZ in forum CNC Machining Centers
    Last Post: 08-11-2007, 07:25 PM
  3. HOW BIG IS YOUR CNC Machining Center?
    By boxxer_boy in forum CNC Machining Centers
    Last Post: 04-10-2007, 11:31 AM
  4. D&M 4 Machining Center
    By bill south in forum Uncategorised MetalWorking Machines
    Last Post: 07-17-2006, 11:21 AM
  5. New Machining Center
    By porsche1220 in forum CNC Machining Centers
    Last Post: 04-28-2006, 12:34 AM
