587,646 active members*
3,032 visitors online*
Hybrid View
    Sep 2005
    4
    Fanuc 18i MB Optional Parameter HELP
    Hi there, need some help here. I have few shizuoka Fanuc 18i MB Vertical Mills. Two of them that I have, the optional parameter that set the MAX programs files that allowed in the machine is 125 Programs, and the others are set to 400 programs. I have no idea which optional parameter to change in order for me to have 400 programs allowed. So I compared all the optional parameters from the different machine and the only difference that I can find is one #9000 Series parameter. And when I try to change it to see if it is the one, the machine gave me an alarm (#OOO Please Turn OFF the Machine POWER). At first, I thought I changed it and the machine need a restart. But after relized that when I try to change it , the value CAN NOT be overwrite and the same alarm just keep poppin up. ANY IDEAS? ThaNks
    Aug 2007
    31
    parameter help
    hi, i beleive parm #9923b5 is for 125 programs, parm #9935b6 is for 400 programs. nakatome
    Dec 2003
    24220
    I have not had that much experience with the Fanuc i series, but I gather that there is a password now to edit the option parameters, probabally because with the older systems, everone knew them, and Fanuc was losing money.
    Al.
    Albert E.
  1. Fanuc 18i optional parameter change
    By jojojoo in forum Fanuc
    Last Post: 02-27-2024, 06:52 PM
  2. Fanuc parameter 901
    By mistux in forum Fanuc
    Last Post: 12-04-2009, 06:28 PM
  3. Fanuc OT parameter(s)
    By erwin1958 in forum Daewoo/Doosan
    Last Post: 03-27-2009, 04:36 AM
  4. Fanuc 6M parameter
    By Garto in forum Fanuc
    Last Post: 06-23-2007, 01:36 AM
  5. Fanuc 3m parameter
    By salmve in forum Fanuc
    Last Post: 06-01-2007, 05:11 PM
