603,767 active members*
4,141 visitors online*
Results 1 to 7 of 7
    Nov 2015
    Fanuc 31i Ignoring #3000 Call
    Hi all,
    I'm not sure why, but my machine is ignoring my error call. The code at the beginning of my tool change program is as such:
    O9006;
    M197;
    IF[#1008EQ1]GOTO1;
    IF[#1010EQ1]GOTO1;
    #3000=1(ERROR TOOL CHANGE);
    M00;
    M30;
    N1;
    some code
    So the machine does halt execution but no error is thrown. Does anyone know what might be going on here?
    Thanks!
    Feb 2015
    161
    Re: Fanuc 31i Ignoring #3000 Call
    maybe a stupid question.. Is there a space between "=1" and "(Error...)"?
    #3000=1 (ERROR TOOL CHANGE)
    Jul 2010
    118
    the machine stopped, so the alarm were not ignored.
    the display did not changed because setting is 3111#7=1, configured not to change.
    Nov 2015
    STLMachinist,
    No, no space. Luckily the Fanuc control panel won't let you add a line of code if you make a simple syntax error.
    Norbert,
    It turns out that the machine was halting because of another line somewhere else. The 3117 parameter deals with available displays for the operator on the 31i, so it wouldn't have made a difference.
    I did end up resolving this by using different line numbers. As it turns out, N1 was used elsewhere in the macro so the machine didn't really know what to do. Once I changed line numbers, it worked just fine.
    Thanks all!
    Jul 2010
    118
    Hi Paul,
    good you found the cause,
    it's always good not to duplicate line numbers in the same file..
    regards
    Nov 2015
    3
    Hello, can someone help me with a post processor for cimatron10 to 3_3 + 2_ and 5 axis cnc to matssura mx520 with fanuc 31i, thanks ...
    Feb 2006
    1792
    I use line numbers only when it is absolutely necessary.
  1. Replies: 5
    Last Post: 09-26-2013, 08:49 AM
  2. Fanuc 11m call sub program
    By rick kroeze in forum Fanuc
    Last Post: 04-21-2012, 04:59 PM
  3. VF2 ignoring M00
    By dingo0722 in forum Haas Mills
    Last Post: 04-11-2012, 01:43 AM
  4. Replies: 16
    Last Post: 10-11-2010, 01:02 AM
  5. Replies: 4
    Last Post: 05-15-2010, 05:02 PM
