603,365 active members*
3,784 visitors online*
    Mar 2010
    17
    Fanuc 3M RS232 problem
    Hi all,
    I am in the process of getting an old Leadwell VMC connected to my laptop. I have worked through most of the problems, and I can now send programs from the CNC to the laptop. However I cannot load a program from the laptop to the CNC memory. Here is what I have done or checked so far:
    The cables:
    Fanuc Honda Fanuc DB-25
    9-------------------------2
    8-------------------------3
    20-------------------------4
    19-------------------------5
    18-------------------------6
    17-------------------------7
    16-------------------------8
    5-------------------------20
    Yes, I had to rewire both ends of the factory cable. I am not sure why it was wrong, some people sould not be left alone with a soldering iron! Anyway I found the pin outs for the honda here on this site for a 6M, and they were also in the maintenence manual.
    Fanuc DB-25 9 pin serial
    2----------------------------2
    3----------------------------3
    7----------------------------5
    4-5
    6-8-20----------------------1-4-6
    I have tried all the combinations for the 6-8-20, 1-4-6. Ie some say not to hook them together some say do. All the combinations work for me, there was no change. I can still only send from the CNC to the laptop.
    I am using Cadems NCnet lite free software. It is set to 4800, 7, e, 2. I have tried different flow controls right now it is set to none. I also checked the system page on the laptop and set the port FIFO settings the same as the software. I also slowed the baud rate down. No change, just slower.
    Parameter 005 is 10000011. Some where I read that parameter 0014 needs to be set a certain way, but my book says that 0014 is only used if the I/O is set to 1 whid it is not.
    TVON is 0
    I/O is 0
    EIA / ISO is 1
    I cannot find the problem. Unless it is a cable problem, but I have ohmed them twice and all seems well. Any thoughts, guesses or comments are welcome (needed...please
    Thanks in advance,
    Dan
    Mar 2010
    17
    more info
    Tonight I rechecked my wiring, and all is good. By stopping the software before the file is transfered I can get the control the through a 086 alarm wich is a data ready signal lost during a rs232 input. So I guess something is getting throught. Maybe I have a program format problem? Also when I out put a program from the control, i get this:
    &he:%
    :2222
    G00 G90........
    The &he: I have not seen before. I have tried sending programs as output with the &he: and with it removed. I changed the : to an O. I added an empty line to the top of the program. Nothing seems to work.....yet. Any ideas?
    Dan
  1. Yasnac i80, Rs232 problem
    By dewcnc in forum DNC Problems and Solutions
    Last Post: 02-18-2011, 07:03 AM
  2. Com Problem RS232
    By bigalow in forum DNC Problems and Solutions
    Last Post: 04-25-2008, 05:16 AM
  3. RS232 to Fanuc problem
    By rchunter94 in forum Fanuc
    Last Post: 04-24-2008, 02:01 AM
  4. Problem with RS232
    By giorgis in forum Fanuc
    Last Post: 01-21-2008, 01:01 PM
  5. Rs232 Problem
    By j-radkemachine in forum Haas Mills
    Last Post: 10-06-2006, 04:03 PM
