587,998 active members*
1,834 visitors online*
Results 1 to 11 of 11
    Mar 2005
    5
    FANUC 6M - IPL MODE PROBLEM
    Hi All,
    I have old machine with Fanuc 6M controll.
    After power ON: ERROR 901 is displayed.
    So i want to initiallize BMU unit.
    I go to IPL mode by press . - and POWER ON.
    IPL mode is displayed and here is finish.
    Not possible to chose enythink.
    Its display fifth functions - but pressing each NUMBER dont change nothink.
    Still same IPL main screen.
    Tested with all four possible states of PWE and MBU FREE switches.
    What i can do more?
    Is is possible that EEPROM program have some problem? But IPL screen is displayed propertly.
    Thanks to any help!
    Best regards
    Darek
    Dec 2003
    24220
    Does this help?
    Al.
    Attached Files Attached Files
    Albert E.
    Mar 2005
    5
    Thank you for this manual.
    This is exacly what im dooing.
    In my case - after press and hold . - and power UP im go to IPL MODE screen.
    And there is menu no.4 - bubble mem. init.
    But my problem is that IM NOT POSSIBLE to chose ANY option from IPL MODE screen.
    regards
    Darek
    What is the part number of your master board?
    The 6A control did not support reinitiallize of the BMU.
    Mar 2005
    5
    Thanks for reply,
    The main board no. i can provide tommorow.
    But if 6A system not providing BMU init. why i have no 4 posible in IPL mode.
    No. 4 means BUBBLE mem init.
    Of course as i told before - its not possible to chose enythink from IPL.
    Its look like machine is making freeze after go to IPL mode.
    darek
    Mar 2012
    5
    Hi All,
    Need Help!- FANUC 6M
    After power ON:
    display stuck on: (Slave ready system 6 M to 3) on fanuc
    Mar 2012
    5
    Hi All,
    After power ON:
    Oct 2009
    297
    Try to adjust +5V at the power supply. If you have another machine I would swapp the power supply first.
    A14B-0061-B001 = A14B-0061-B002
    Regards
    Alex
    Mar 2012
    5
    Red face help
    Hello all the request I need your help:
    punch press Strippit Cap 1000 has digital control I have the following problem: the machine does not start and remains stuck on the first display (system ready save 6Mseries M 35 to 03).
    And not start with a (No. 0 lead in turn worm on Wed A16B-1000-0030/06C fanuc card) and Mercia miles
    thank you alex
    Mar 2012
    5
    Hello all the request I need your help: Strippit Cap 1000 has digital control I have the following problem: the machine does not start and remains stuck on the first display (system slave ready 6Mseries M 35 to 03).
    Oct 2009
    297
    Quote Originally Posted by elmrini View Post
    Hello all the request I need your help: Strippit Cap 1000 has digital control I have the following problem: the machine does not start and remains stuck on the first display (system ready save 6Mseries M 35 to 03).
    Regards
    Alex
  1. What is - Torque Mode? Position Mode? Speed/Velocity Mode?
    By sunmix in forum Servo Motors / Drives
    Last Post: 01-20-2024, 10:34 AM
  2. Fancu 10M IPL Mode problem...
    By madkins in forum Fanuc
    Last Post: 01-21-2019, 05:27 PM
  3. Fanuc 0M stays in MDI mode
    By malaron in forum Fanuc
    Last Post: 08-06-2007, 11:19 PM
  4. Problem with CV mode
    By mariano_mdf in forum Machines running Mach Software
    Last Post: 03-11-2007, 08:28 PM
  5. Fanuc tape mode
    By mroy0404 in forum Fanuc
    Last Post: 03-17-2005, 10:15 PM
