603,872 active members*
3,343 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Feeler VMC Tool Changer Problem - Urgent Question
    Jan 2011
    43
    Exclamation Feeler VMC Tool Changer Problem - Urgent Question
    I have a 2006 Feeler VMC with a carousel toolchanger and Mitsubishi Meldas 60S control.
    I don't know the proper toolchanger command format or I might have a functional problem.
    Is there a toolchanger dry run program or cycle I need to run?
    The machine was shipped to the US from China. It thinks tool #20 is in the spindle.
    If I program M06 T01 in MDI and run it, the spindle goes up, the carousel moves right, the spindle rises and the carousel rotates more than 360 degrees and then throws an error.
    Apr 2002
    5003
    If you have a tool in the spindle, than you first should remove it. If no other method is provided, you should search for the solenoid valve for the Toolcylinder.
    If you have access to the parameters, you should look for the toolrevolver. I think there is a parameter who is called "axis is modulo" or similiar, then try to change it from 0 to 1 or viceversa.
  1. TOOL CHANGER PROBLEM
    By jmill in forum Fadal
    Last Post: 04-21-2012, 03:43 AM
  2. 0ma tool changer problem
    By curtistdc in forum Fanuc
    Last Post: 06-15-2010, 12:20 AM
  3. tool changer problem
    By kling8 in forum Mori Seiki Mills
    Last Post: 02-25-2010, 02:54 PM
  4. tool changer problem
    By concordezz in forum Haas Mills
    Last Post: 08-20-2008, 09:04 PM
