603,848 active members*
4,157 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > finding center line x geometry offset!
    Mar 2009
    18
    :Machine Dawoo V-15 twin spindle. Control, fanuc 16T.
    Have a job that requires drilling a 2.125" hole in a flange. so I installed a 2.125 Ken. fixed drill. I thought the x geometry offset was x0 for the center line, but not the case. so after investigating, I discovered the the work coordinate page (g54) reads x19.531 so I input x-19.531 in the geometry offset page. and ran a part. It drills the hole exactly .200 bigger than 2.125 at 2.325 not a big deal since the I.D. of part finishes at 3.0 but how can I find the true center Line?
    Dec 2009
    1121
    Re: finding center line x geometry offset!
    you mount a dial gauge with 0.01mm division and stick it with magnet or mount it on a piece with a hole to the spindle ,bring the tool with X0 command and put the clock on the drill and rotate the spindle around the drill.
    the spindle will generate a perfect circle and your dial should read almost 0 in the X axis direction,if not you can easily move the X axis untill you read same value on X axis direction.
    maybe you will have some deviation on the imaginare Y direction(if your machine do not have Y axis)that is perpendicular to X axis.
    if your machine has Y axis ,it is easy ,you just move the Y axis and X axis in the direction you want to have a perfect 0 when you rotate 360 degreee the spindle.
    after you are finish,just copy the X axis machine value to work**** page and for Y axis you have to reset it by parameter 1815 APZ making it 0 and 1 again.
    if your machine do not have Y axis and you have some deviation on the imaginary Y axis that is perpendicular to X axis ,you have to rotate mechanically the turret by releasing the screws from curving coupling and hit easily with a hammer untill you read almost 0 on your dial.
    this is a work for a service guy,so is better to call one or be assisted by one.
    have a good day.
  1. Replies: 11
    Last Post: 12-17-2016, 04:59 AM
  2. Replies: 1
    Last Post: 05-22-2016, 10:59 PM
  3. Replies: 17
    Last Post: 09-14-2015, 02:48 AM
  4. Geometry offset
    By Amboy in forum Fanuc
    Last Post: 07-21-2014, 04:30 AM
  5. Finding self intersecting geometry
    By MetropolisCNC in forum Solidworks
    Last Post: 06-03-2009, 05:46 AM
