587,997 active members*
2,191 visitors online*
Page 1 of 10 123
Results 1 to 20 of 191
    Sep 2010
    528
    First Machine Build
    Here is a look at my first CNC machine. It is still a work in progress but it is coming along nicely. I am actually using it to build itself.
    I'll start with a picture of the machine at it is now, and then start at the begining.
    Oct 2008
    406
    Umm, what picture?
    Bob
    "Bad decisions make good stories."
    Aug 2010
    Whoaaa, it's invisible, too !!
    "I'm tryin to think but nothin happens" - Curly Howard
    Sep 2010
    528
    Quote Originally Posted by Woodbutcher-59 View Post
    It's not invisible, I sprayed it with clear coat!
    Let me see if I can re-post the picture. I'm new here and climbing up the learning curve.
    Aug 2010
    Take your time...no big deal !!!
    Just wanted to bust your chops a little...:cheers:
    Where can I get that clear coat....it works real good!
    Jeff
    Sep 2010
    528
    Here is the concept drawing for the first prototype. I decided that I wanted a CNC router made of 8020 extrusions, but to keep the cost of mistakes to a minimum I decided to build the router out of MDF first as a prototype.
    Here is the design I settled on. You will see ideas from an assortment of different machines, mostly gleaned from other builders websites.
    The X and Y axis are driven by #25 roller chain. The Z axis is lead screw. The steppers are 475 oz. with matching drivers from Keling Inc.
    Linear guides are V-bearings on aluminum angle.
    Sep 2010
    528
    Here is the first machine. It worked quite well.
    The router is a Porter Cable 690. I was ale to cut MDF and plywood at 60 ipm and aluminum at 3 ipm.
    The first machine worked well enough to help build the second.
    Sep 2010
    528
    Here is a look at the new machine as it was going together.
    The gantry is 80/20 extrusion (40-8016 ) carried by legs cut from 1/2" 6061. The carriage and Z axis are guided by V-bearings on V-rails from Pacific Bearing. Their V-rails are hardened steel and are embedded in aluminum extrusions. The bolt right onto the 80/20 extrusion. The V-bearings are mounted on either concentric bushings or eccentric busings for preload adjustment. I tighten the eccentric bushings until I can just barely roll the V-bearing by hand. There is no play in the setup at all.
    This table is made of MDF with the aluminum angle as bearing guides because I was not sure if the gantry legs would be stiff enough not to flex. Now that I know the legs are stiff enough to support the gantry with no flex I am going to build a new table out of 80/20.
    I am considering filling the 80/20 table with epoxy granite to add weight, but I will wait until after the table is built to see if it is necessary.
    Apr 2007
    1955
    Hi, I will be very interested to see how you like the V bearings. I am considering them for a project as well. What size did you end up using ?
    Sep 2010
    528
    Quote Originally Posted by harryn View Post
    So far I like the V-rails and bearing very much. They are less expensive than most linear rail and bearing combos. I paid $9.99 each on ebay for the bearings. The rail was about $60 for a 48" IVT from Pacific Bearing. The rail bolted directly to the 80/20 extrusion.
    They are self centering, and the preload is very easy to adjust. They are also very easy to clean and lubricate.
    I don't have the exact specs in front of me, but they are about 1" in diameter and are sized for a 3/8" shaft. The bushings are sized for a 6m bolt.
    I have seen a few commercial machines that use them, including shopbot.
    J
    Oct 2009
    Even though I have been watching this site for about a year I am just now getting time to put together my first table. Your design looks like something that would not break the bank but be very functional for a first timer. The majority of my planned work is in wood so I do not think I would need something strong enough to handle metal. Biggst problem is where to start. Your unit looks great.
    Mar 2003
    35538
    Virtually all those bearings, regardless of the manufacturer, have the same specs. And the bushing have a 1/4" hole, which is larger than 6mm. You might want to check that, as using 6mm may allow the bushing to move a bit. Although, if they're eccentric, and you have them tight, I guess they can't.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Sep 2010
    528
    Quote Originally Posted by gwsadair View Post
    There are a lot of great ideas out there. I got most of my ideas from Build Your Own CNC Router Machine.
    As far as where to start. Start with the spindle. Pick a spindle that is appropriate for the work that you want to be able to do, and then design the machine to carry it over the cutting area that you need.
    I would suggest not using MDF as a building material. Use a good quality harwood pllywood, or better use MDO.
    Good luck.
    Sep 2010
    528
    Thanks for the head up Gerry, but don't worry. I ordered the metric bushings from Pacific Bearing.
    J
    Oct 2009
    jharvey
    thanks for the info. I actually have an older fixed base variable speed router that I just rebuilt with new bearings and shims. It has a bit of weight to it, but for accuracy and torque I don't think I will find anything better to start with. Now to start planning table size and all the other good stuff.
    Sep 2010
    528
    jharvey
    Sounds like a good start. Keep us posted on your build.
  17. #17
    Sep 2010
    528
    Front View
    Here is a look at the router from the front. I still have a lot of work to do, but it is already running very well and I am using it for work. That accuracy is .010", which works well enough for what I am doing, but I am aiming for .001".
  18. #18
    Sep 2010
    528
    Zero Jig
    I built this jig for referencing the control point to zero anywhere on the table. It mounts in a t-slot and has touch plates for X and Y axis.
  19. #19
    Feb 2010
    331
    I like that zeroing jig, good idea
  20. #20
    May 2009
    435
    I was wondering how you used that zeroing jig since the aluminum angle wasn't flush with the corner of the white part.
    This pic explained it (click on thumbnail):
    Which zeroing program are you using?
    (by the way, how did you get a member gallery)
Page 1 of 10 123
  1. My first CNC machine - Build
    By clocksandblocks in forum DIY CNC Router Table Machines
    Last Post: 07-26-2014, 08:42 PM
  2. My Second CNC machine build!
    By Toaster55 in forum DIY CNC Router Table Machines
    Last Post: 06-23-2011, 12:50 AM
  3. New Machine Build
    By skipper_52 in forum CNC Wood Router Project Log
    Last Post: 04-07-2008, 12:13 PM
  4. Use the second machine to build the first!
    By Madclicker in forum CNC Wood Router Project Log
    Last Post: 06-27-2007, 05:29 AM
  5. Want to build new machine
    By thuffner3 in forum CNC Machining Centers
    Last Post: 02-14-2004, 03:47 PM
