Your picture implies that you are cutting the rectangular pieces out inside a sort of pocket. I foresee a potential problem; just before they fall off they may bend slightly making contact with the side of the pocket and then jamming against the cutter.
Here is an alternate suggestion which could save some handling time.
Do all the tapped holes first in all ten, face the top if that is needed.
Drill an identical pattern of holes in a piece of cold rolled flat bar slightly larger than the overall size of material need for the ten pieces.
Bolt the tapped material to the flat bar, grip that in the vise, machine the perimeters of the ten parts and face the top if that is needed.
Now hold the whole assembly edge on in the vise and tap the holes in one end, then turn it over and tap them in the other.
Remove ten finished parts.
