603,310 active members*
2,444 visitors online*
Page 5 of 12 34567
Results 81 to 100 of 229
  1. #81
    Sep 2005
    197
    Smile
    Quote Originally Posted by WayneHill View Post
    It's like making a cow out of hamburger. All the parts are there. Just don't know how to put it together.
    Nice comment and I have to agree. Inverse ingeneering is not easy
    I have dreamt of making 3D parts from scans and paths. At my work we have a highend 3D scanner (100K $) this creates very nice STL files but what happens is even with a good scan you want some changes and then you find out that its very hard to work with the files. Almoust every time I end up modelling the part up in 3D from scratch. Faster and much more flexible to changes.
  2. #82
    Mar 2004
    761
    It is possible to create a point cloud from a G-Code to a DXF file. Have the CAD software generate a surface from the points. A lot of the surface texture would be missing. It would be possible to generate an XYZ vector points from the DXF line and circles. This could be handy to someone working on a reverse 3D model.
    Wayne Hill
  3. #83
    Dec 2009
    Quote Originally Posted by Switcher View Post
    Wayne, I ported your code to "VB.Net 2005", thanks for the source.
    mikkojay, your VB6 code helped to, thanks both.
    I didn't change much, I might add a file splitter later, maybe split large g-code files.
    Hello and thanks for upload.
    I tried this software on my Gcode and opened the output in AutoCAD but the result wasnt okay.I wrote my Gcode with the aid of CNC simulator(CNCsimulator.com) but im new to this so i had to make some moves to improve my product that maybe confused your program.Im sending you my Gcode in a pm to check it yourself if youre in mood.
    thanks
  4. #84
    Mar 2004
    761
    Liliostasi,
    The original program works with basic XYZ g-code. Anything else will fail to convert.
    Wayne
    Wayne Hill
  5. #85
    Aug 2009
    10
    Wayne-
    I've been gone for a while but thanks for answering my question.
    I loved your quote "It's like making a cow out of hamburger".
    wayne wrote "It is possible to create a point cloud from a G-Code to a DXF file. Have the CAD software generate a surface from the points. "
    I am going to try your method of creating a point cloud from g-code. I don't know what program does this and have had no luck searching on the internet. What program is it?
    many thanks in advance!
    chris
  6. #86
    Mar 2004
    761
    PM'ed
    Wayne Hill
  7. #87
    Aug 2008
    Hi! Evreybody..
    I need help about EMC2. I have projects with aotocat and corell Draw dxf file. But some times I couldn't convert g code for emc2 and also deskcnc open that files.
    If you use better g code converter please help me...
    Atakan
  8. #88
    Anyone Modify this to accept incremetal code
    You don't need Vb.net to run the program, you will need "Microsoft .NET Framework Version 2.0" (Download & install this If it's not already on your PC before you run the Gcode2DXF).
    After you download the .Net Framework 2.0, then download the .Zip file here (latest version post #49).
    After you have the 2 downloads on your PC, unzip the "Gcode2DXF .zip file" & follow the path below to the program (assuming you downloaded the "Gcode2DXF .zip file" to the desktop).
    ...\Desktop\Convert DXF SourceCode\Convert DXF SourceCode\Convert_DXF\bin\Release\Convert_DXF
    :cheers:
    Just wanting to know if anyone has ever modifed the program to accept incremental code.
  9. #89
    File not converted properly
    Can anyone tell me why this file does not convert properly. It creates the outside of the part but does not bring in the circle in the center of the part
    Attached Files Attached Files
  10. #90
    Dec 2008
    17
    gwittlock,
    I converted your nc code using the convert dxf program. Importing the dxf into cadkey, gpuncher and gcad3d the circle showed up. I tried several viewers and the circle did not show up. It seems there is something in the dxf that is not recognized by all viewers and cad programs. Maybe Wayne can look at the dxf output and see it.
    apexengineering
  11. #91
    Mar 2004
    761
    The circle showed up in Vector CAD/CAM. It did not show up in Solidworks eDrawing viewer. The g code looks good. Something flacky on how the viewers translate the circle direction.
    In the viewers: If the arc value is changed from 0 - 360 to 0-359.9999 it will show up in the viewers. I will keep researching.
    Wayne
    Wayne Hill
  12. #92
    Dec 2008
    33
    I was working on an Artcam project that got corrupted. I have the gcode that was created before the file got damaged though. I am trying to get a DXF file from the gcode.
    I have tried another converter that kept all of the above workpiece moves in the output, when I tried to clean it up I was not able to make it work. This software sounds like it would give me exactly what I need since it can ignore the moves above the workpiece. When I run it I get an error though. The error is "Index and length must refer to a location within the string. Paramater name: length"
    The gcode file is here.
    http://alan-parekh.com/wp-content/up..._engraving.tap
    Any ideas?
    Many articles about hacking gadgets. Examples of extreme technology. DIY projects describing how to build electronic projects. http://hackedgadgets.com
  13. #93
    Mar 2003
    765
    See if this works for you, I converted it in NCPlot.
    Scott
  14. #94
    Dec 2008
    33
    Quote Originally Posted by MetLHead View Post
    Scott
    Hi Scott,
    That works perfectly! You saved me hours of work.
    Thanks a million.
  15. #95
    Mar 2004
    761
    abbtech - I was able to convert your file with no problem. Was software was giving you that error?
    Scott - I like your NCPlot software
    Wayne
    Wayne Hill
  16. #96
    Dec 2008
    33
    Wayne
    Hi Wayne,
    It was the one listed on comment #36 or #40. I actually didn't realize there was more than one conversion program or version listed in this thread until I went looking for the comment that I got it from.
    Alan
  17. #97
    Mar 2004
    761
    Talking
    Alan,
    Yes, there have been additional converson programs written and posted in this thread. My original program did not have any error checking in it , so I knew that the error was not generated from my program.
    Thanks,
    Wayne
    Wayne Hill
  18. #98
    Jun 2005
    Wayne,
    I tried your program and it converted the g code to dxf, however it brought in the rapid movements as well. Is there an easy way to eliminate the rapid movements without having to go into the text file and removing them prior to the conversion? Thanks.
    Rush
  19. #99
    Mar 2004
    761
    Rush,
    WYSIWUG. There might be some other programs in this thread that will do what you are looking for.
    Wayne Hill
  20. #100
    May 2010
    Great Work Wayne, its a remarkable program. I simply love it
    Thanks!
Page 5 of 12 34567
  1. Replies: 51
    Last Post: 09-16-2020, 01:28 AM
  2. corel.hpgl > sheetcam.tap > pronterface.g-code > slic3r.g.code> ramps 1.4 > H-BOT
    By thesignworks in forum Uncategorised CAM Discussion
    Last Post: 05-25-2014, 02:11 PM
  3. Cambium Code Web Tools – Parametric G-code Generation
    By CambiumMachines in forum News Announcements
    Last Post: 12-19-2012, 04:37 AM
  4. Replies: 8
    Last Post: 12-15-2010, 09:32 PM
